energy suspension bushing into ksport lca?
can i put the energy suspension bushings that ive purchased into the ksport lca? I know that most common problems with lca's is the bad bushings that they come with, so i was thinking about throwing the energy suspension ones into the ksport lca. Also can you bolt up the stock sway bar to the ksport lca? ive heard problems with other brands and the sway bars not fitting
depends on what car you are talking about........
if the bushings are the same size then yes they will fit.
sum LCAs have small bushings liek the BLOX junk.
its a 01 integra, the bushings are the energy suspension lca bushing set and the ksport lca's would also be for the 01 integra
right. but also like the blox RLCA the actual bushing is a dif size.
i had blox rlca and i had energy suspension bushings for the rlca...but blox bushings were smaller.
of course you can always trim them down but thats ghetto,
match up teh stock and ksport rlca and see if they have the same size bushing. if so then the ES bushings will work
thanks broski i appreciate the help, i dont have the ksport lca's yet i was going to order them once i knew they could fit, i dont see why they shouldnt though!
i doubt the ES bushings will fit the LCAS. i had a set of megan LCA's i was going to use on my DA, but discovered the ES bushings did not fit. i sold the LCA's and installed the bushings in my OEM arms. the k sports seem to be the exact same copycat-different-color-anodizing as all the other crappy LCA's out there. IMO, dont waste your money on them, just put your bushings into your stock arms. clean them up and have them powdercoated while you're at it. my $.02.
Measure the size and order a bushing or heim for the LCA.
K sports are the same junk LCA that everyone makes, but the only change from the "good" LCAs is the bushing.. something I can do better for less than they will sell a good one.
Historyg
10
Dec 17, 2007 01:01 PM
g2b2
May 2, 2007 10:37 AM
dvp
Mar 15, 2006 04:08 PM
