Steering Problem Need Help ASAP
Old Sep 20, 2002 | 12:57 PM
cybspur's Avatar
Default Steering Problem Need Help ASAP
Before I get flamed, I did do a search, and nothing that fits my description came up so....I just changed my tie rod ends, left and right, because after research and talkin to peeps, they say that it might fix my problem(which it did not), which is: My steering wheel is loose. Whenever I hit a bump, my steering wheel will turn to the left or right depending on which wheel hit the bump. Also in order to go straight the steering wheel has to be turned abit 'O ways to the right
(95-100 degrees?). Also if I let my hand off the wheel while the car is moving the steering wheel will start turning to the right. Ok, hope yall can help while I got the car jacked up. Thanks
1990 Civic EX
Double Post....its also in the crx/civic forum, just thought maybe more peeps will see it here...and respond while I got my car jacked up.
94ej1coupe206
Jun 20, 2017 11:38 AM
Danielsb20crx
39
Jan 6, 2013 01:02 PM
^^ gökan^^
Suspension & Brakes
Jan 31, 2010 11:53 AM
cybspur
Sep 20, 2002 02:33 PM
