90 Civic Hatch/ Cluster Electric Problems
Old Oct 24, 2010 | 10:43 PM
JDMhonda90's Avatar
Default 90 Civic Hatch/ Cluster Electric Problems
im having a problem with my cluster when im using my turn signals and high beams, everytime i use my turn signal my rpm gauge and temperature gauge are jumping up and down and wen i turn my high beams the high beam light starts blinking a lot with my rpm gauge and temperature lol its funny but seriously annoying... ive tried checking every ground in the car, taped wires that where cut and not connected, im missin pivot bolt on my alternator the bottom one idk if it might be that.
anyone know what it might be?
Old Oct 26, 2010 | 12:24 PM
JDMhonda90's Avatar
Default Re: 90 Civic Hatch/ Cluster Electric Problems
nobody knows???
Old Oct 26, 2010 | 12:30 PM
singlecamsaint's Avatar
ive got a similar problem whenever i turn my blinkers on my temp gauge jumps with the rhythm of the blinkers and also when i turn on my high beams the gauges just completely spike. i too have been all over the grounds and cant find crap
Old Oct 26, 2010 | 12:31 PM
Pagley's Avatar
check the wires for any electircal shorts, sounds like a problem i had and sure enough it was shorting out on something
Old Oct 26, 2010 | 12:39 PM
guess i better go pull the dash then cause every ground including the headlight grounds are bueno
btw are there grounds behind the dash and where are they if so
Old Oct 26, 2010 | 12:54 PM
Pagley's Avatar
it may not just be grounds but if the wires are showing it can be grounding out on the frame of the car somewhere. could be behind the dash or in the bay. basically you just have to find those wires and trace them back to the fuse box or relay
Old Oct 30, 2010 | 10:37 AM
JDMhonda90's Avatar
its easy to fix, all you have to do is unplug your cluster, take it all apart and blow inside the plugs might be some dust in there that wont let the cables get complete power through, and everything else started working perfect now
Old Oct 30, 2010 | 11:00 AM
hatchet_honda's Avatar
your missing the lower alt. bolt? wow get another one of those lol
BrandonR
Oct 15, 2011 08:00 PM
Dpfan
Apr 5, 2011 11:49 PM
byrne_06
Oct 24, 2010 03:31 PM
ilovemydc2
Nov 18, 2004 10:04 AM
Sack Master
Oct 22, 2004 04:49 PM
