1990 prelude si 2.1
car in on position just don't turn it over and have paper clip or wires in the plug on passenger side and count the code the search it on forum that's what i do... Did
thank you next question the car started to have a miss then it got hard to start then it quit starting all together i checked it out and found it had no spark from coil or plugs what should i check maybe voltage regulator or what other componet
my car is have the same problem i have a 98 prelude i car wont turn on i change the distrubitor wire spark plug main relay check the fuel presure is good change the coolant heat sensor my car only get spark if i crank it alot then it turn on but if i shut it of for 30 m it wont turn back on onless i crank it alot wat can i be
IWearMyKswiss
Sep 17, 2004 09:49 PM
