Suspension & Brakes Theory, alignment, spring rates....
Old Apr 1, 2015, 01:50 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
Print Wikipost
TIE ROD END REPLACEMENTS
Old Oct 24, 2010 | 05:55 PM
k20eklipse's Avatar
Default TIE ROD END REPLACEMENTS
i got a question, iv been confused about this since i needed to replace my tie rod ends
when you buy replacement tie rods, do they come with the tie rod ends or is it just the tie rod itself ?
someone answer this, thank you
Old Oct 24, 2010 | 06:21 PM
k20eklipse's Avatar
Default Re: TIE ROD END REPLACEMENTS
meaning if i buy this
http://cgi.ebay.com/ebaymotors/2-199...Q5fAccessories
it comes with both tie rods and tie rod ends correct ?
someone help me with this
Old Oct 25, 2010 | 01:31 PM
02 accord's Avatar
There is an inner tie rod end (tie rod as you call it) that connects to the rack, and an outer tie rod end that connects to the knuckle. The ebay kit only contains the outers.
Old Oct 25, 2010 | 07:05 PM
gabebauman's Avatar
I recently did this with my 93 Civic hatch and I can tell you right now...it's best to get the inner and outer tie rods at the same time so you can save yourself the trouble of doing it twice. Besides that...you'll only need to make one trip to the alignment shop after you install them.
I got mine at NAPA...roughly $40 per side, ($18-20 per tie rod...inner and outer).
You'll need two number 1's (inner tie rods) and both number 23 & 26, (left and right outer tie rods that have the ball joints on them).
Old Oct 26, 2010 | 04:40 PM
k20eklipse's Avatar
thanks gabe
well im replacing my axles, tie rods(inner & outer) and my rack&pinon
they all decided to go at the same time *thumbs down*
right after i did my ball joints too smh. but i should be getting everything for pretty cheap so we'll see what happens, just gotta find a place to put the rack&pinon in for me. axle & tie rods i could do
any reputable shops in the nyc area ?
Old Oct 26, 2010 | 06:11 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Just get an entire rebuilt steering rack. I replaced my outer tie rod ends some years ago, then later replaced the whole rack that came with the inner tie rods only. So I had to swap my relatively new outers over to the new rack.
Yes it's a PITA to replace the rack with the engine in the car (at least on a GS-R) but I was able to do it in my garage.
Old Oct 26, 2010 | 07:03 PM
k20eklipse's Avatar
Patrick do you know where i could get one ?
cause i found the inner and outer tie rods/ends for 50 bucks. then axles for 50 bucks
& a rack&pinon for 80.. so which do you think would cost more ?
Old Oct 27, 2010 | 05:14 AM
qk_boosted_b17's Avatar
I am planning on doing the tie rods pretty soon, I might just buy a whole rack.
Old Oct 27, 2010 | 06:00 AM
Community Builder
When you say rack & pinion, are you talking about the entire group of parts outlined as #2 above, or a specific part or parts?
I bought a complete rebuilt steering rack in 2007 from a company that uses all OEM Honda parts in their rebuilt units. It came with inner tie rods and was about $240 after core.
Old Oct 27, 2010 | 03:57 PM
k20eklipse's Avatar
[QUOTE=PatrickGSR94;43871667]When you say rack & pinion, are you talking about the entire group of parts outlined as #2 above, or a specific part or parts?
um im going to get the rack&pinon, im not to sure exactly what it is
but its #22 to the left of it. its ripped
so my mechanic was like i gotta replace the rack&pinon
cause its def creeking & **** & my boy's supra used to do the same
so he said its def the rack&pinon
Topshot
Apr 9, 2012 07:11 PM
Toxic H
Jun 11, 2010 05:23 PM
Tizzlers Ep3
Aug 3, 2006 06:02 AM
yOnKiNaToR
May 17, 2005 11:46 AM
Yellow00TypeR
Mar 3, 2003 07:18 PM
