FS: PA: 95 hatch 2.0L 638whp
Specs:
Chassis:
1995 dx hatchback
Exterior-
gray-bronze (like a charcoal w/ bronze flake)
carbon fiber hood
17" ADR wheels
Nitto NeoGen 205/40/17s
skunk2 pro-c coilovers
skunk2 pro camber kit
avid racing pro traction bars
no-name sway/tie bars, C pillar brace
gsr disc brake conversion front and rear
new drilled/slotted rotors and brakes
TYC one-piece projector headlights
custom drag front bumper, intercooler cutout only
Interior-
black interior
black floor mats front and rear
Si 9k cluster
AEM EUGO wideband
Autometer boost gauge
Sunpro oil pressure gauge
gsr shift ****
gsr front seats
pioneer cd player
pioneer 6x9 speakers in the rear
sony xplod 3x5 speakers in the front
Powertrain:
Motor-
Block:
2.0L 84mm Darton MID sleeved b18c1 block
Eagle connecting rods
Arias 9.1:1 low comp pistons
ACL race rod&main bearings
ARP headstuds
GE head gasket
Head:
Endyn p72 Stage 3. Professional Full-Ported package
including valves, springs, retainers, locks, and guides
Skunk2 Pro-1 camshafts
Skunk2 Pro series Ti cam gears
GE thermal shield intake gasket
Edelbrock Victor X intake manifold, ported, port-matched 76mm throttle body intake
Blox 76mm throttle body
Transaxle-
'01 gsr hydro 5 spd
Mfactory LSD
ClutchMaster FX700 twin disc
Forced Induction-
Bullseye Power T3 S362r extended tip
upgraded exhaust wheel (same as t4, just in t3 housing)
(wrapped in DEI Ti turbo blanket)
StraightLineSpecialties Proto-type T3 Exhaust Manifold
(wrapped in DEI Ti heat/header wrap)
Tial 46mm wastegate
Open 2" dump-tube, flush with traction bar
Synapse backdoor intercooler
GM 4bar map sensor
FullRace vacuum block
3" aluminum charge pipe
Greddy Type R 50mm bov
4" vband downpipe
Mid-pipe reduces 4" to 3"
-can be removed for straight 4" downpipe with turndown
3" straight exhaust, mid-pipe back
Fuel-
Walbro 255 intank
Bosch 044 inline
T1 relay and install kit with stainless lines, etc
AEM fuel rail
FuelLab fuel pressure regulator
InjectorDynamics ID1000 injectors w/ ob1/uscar adapter caps
Other motor stuff-
3 row aluminum radiator w/ aluminum shroud and slim fan
B&M short throw shifter assembly
Hasport shift linkage
MSD blaster ss external coil and pro distributor cap
Failsafe 160 degree thermostat
P72 power steering system
Haas catch can setup w/ stainless lines & B&R block fittings
Hasport 88a black mounts
Hondata daul stage electronic boost controller, not hooked up
just closed solenoid with 1st stage set at 18psi
*** 638whp, 401wtq @ 20psi on 93 octane
Ok, thats a decent list of specs, maybe add a few i forgot later.
Right off the bat, the body is not perfect, there are some imperfections here and there from normal wear, and each quarter/wheel-well has a small rust bubble forming (smaller than a dime) under the paint and that is the only rust.
As for the car, its mint. Mobil 1 Synthetic and Wix filters for the motor. Mobil 1 synthetic and Synchromesh for the trans. Don't be fooled, its more of a race car than anything. I daily drive it, but getting used to the hp, twin disc, and motor mounts is something that takes time/skill.
I just feel like moving on to something new, so I figured i'd throw this up.
The price: $14,000.
Winter Special: $13,000 obo.
or $10,000 obo w/o the endyne head
Im not looking for any trades, just CASH.
but maybe for an 05ish VW Passat TDI, black leather.
I'm located in Northeast PA 17872.
PM me with serious inquires only.
(^sorry, only one i have from my phone, here at school)
so yea, thats my car. my main interests are performance, and thats what it was built for. i was going to weld a cage in it this winter but didn't want to drop the value if someone didn't want it in there. regardless, you wouldn't be disappointed.
once again, just contact me via PM, serious inquires only!
Price again is $14,000.
No trades.
Or maybe for an 05ish VW Passat TDI.
Thanks for looking.
Chassis:
1995 dx hatchback
Exterior-
carbon fiber hood
17" ADR wheels
Interior-
black interior
Si 9k cluster
AEM EUGO wideband
gsr shift ****
gsr front seats
pioneer cd player
Powertrain:
Motor-
Block:
ARP headstuds
GE head gasket
Head:
Transaxle-
'01 gsr hydro 5 spd
Mfactory LSD
Forced Induction-
Tial 46mm wastegate
GM 4bar map sensor
4" vband downpipe
Fuel-
Walbro 255 intank
Bosch 044 inline
AEM fuel rail
Other motor stuff-
***Ok, thats a decent list of specs, maybe add a few i forgot later.
The price: $14,000.
No trades.
Thanks for looking.
yea, def great numbers. as you can see by the specs, i chose everything to a T for the "best" (most hp efficiently) build.
i did have it on race gas before the tune, but decided to daily it and race gas would be too expensive for that, so i switched to 93. i wouldn't mind re-dynoing on race gas just to see the numbers. i'm sure it'd be well over 700 and the turbo seems like it has alot left in it (for only a 362). and hell, if someone wants a drag car outta this, i can throw in a full-race front mount, upgraded s372r and air-water setup for a better price that i have listed now. haha.
& yes, the car is extremely fun to drive. doesn't skip a beat. handles great and pulls very hard (when it hooks up, hah).
haha, yea, it'd be nice to see some crazy numbers. but unfortunately, im growing up.
i have a post in the drag section too, at the top of page two, everyone can check that out.
84mm sleeved block, 89mm stroke. s372r. front mount mani. air-water.
i would really like to strap the endyne head onto that bottom end, buttttt its time to move on, finances are changing, graduating college, etc.
ahh how times change...
