+50 pictures.....fall sales (ef/eg/dc/accord)
woah... I made $160 so far... thanks honda-tech... keep the PM coming
DA 4040 ppv = $20
All prices are OBO unless stated otherwise
Don't lowball as my prices are already low
I can take trades
See vouch thread in sig
I take paypal or MO
Thanks for the support
Charlie Moua
PM, call or text me 651-226-7157
Volvo oil cooler - MINT $35
Exedy Stage 1 clutch
Good for 260lbs tq
less than 5K miles... excellent clutch (miles are documented. Yes I keep a car journal...LOL)
Bought for $270 new
Selling for $165
Apexi turbo charge pipe 2.5" with Apexi Twin Chamber BOV = $150
used only for 3k
stock gsr oil pan $30
stock gsr 60mm throttle body no tps/no IACV $25
Honda throttle body 56mm, 58mm (from D/B series) $10 or $30 with good tps
y8, y7, b18a1, gsr, throttle body (some have new TPS) $5-25 depends on which one you get
EK D series PS bracket = $2
13) ARP D series rod bolts (never opened)
Bought 6 months ago at MAP for $38, selling for $30
[B]
(3) Data logging cables… used for ECU to computer (bought 6yrs ago, discontinued) = $30
B series fuel rail = $10 (polish it to dress up your bay!)
EF si 3540 proportion valve = $3
OEM EF mud flaps in great condition = $35 *** pending ****
autometer pillard dual pod = $15
OEM gas cap = $5
y8 timing belt cover = $3
y8 header heat shield = $3
D series flywheel cover = $2
9x5 civic battery cover = $2
d16a6 throttle body with good TPS = $10
honda 14" steelie with good tire = $10
[img]https://farm5.static.flickr.com/4087/5063910966_69cbe78965.jpg[/img
OEM oil caps - $1 each...(8)
EG napa air filter (less than 4,000 miles) = $3
OEM 92-95 civic hatch/coupe turn signals = $10
Took them off in 1999 off 95 civic with 55K
94-97 accord rear reflector = $2
Tanabe RM silencer = $5 (never used)
stock b16 cam gears = $2
EG coupe rear sway bar with good bushings = $2
VX 5wire o2 sensor (NTK sensor that last forever!) $35
Injectors (left to right) DA, EK, B20 = $15 a set
red oil cap....(peal off the CF sticker if you want) = $10
OEM radiator cap (92+ hondas only) = $5
New D16 spark plugs (never used) = $5
MSD ignition distributor cap 90-97 accord non vtec = $10
MSD (NEW) blaster coil wire (3ft) & replacement ends = $10
*** I used this on my accord... but the box says it works on civic too so check the P#.
90-91 civic bumper lens = $1
DA 4040 ppv = $20
I can take trades
I take paypal or MO
Charlie Moua
Good for 260lbs tq
Bought for $270 new
Selling for $165
used only for 3k
[B]
OEM gas cap = $5
large cone filter 3.5" inlet = $10
OEM MAP sensors = $2
OEM FPR = $2
DA cable & EG hydro VSS = $15 each
Spring bolts, valve cover grommets/buts, spark plug wire holder, plastic crews, bumper screws, flywheel bolts, auto tranny bolts, header bolts & studs, ect.... $0.10 each
OEM FPR = $2
da9blk1
Mar 23, 2011 03:50 PM
