Mid-Atlantic (Sales) VA, DC, and MD
F/S Acura Integra B18B1 Engine, Transmission Exhaust System and More
Old Oct 24, 2010 | 10:45 AM
mocchiuto's Avatar
Default Parts now for sale separately, F/S Acura Integra B18B1 Engine, Transmission and More
Hello: these parts are located in Winchester, Virginia, My name is Michael and you can contact me through the forum for any questions, The price for the entire lot of parts is $500, please do not send me offers for less. You will need to pick up these parts, I cannot deliver them.
I have a lot of extra parts that I no longer need so I am going to get right down to it. This would be great for a person with a second generation Integra 1990 to 1993.
First is a B18B1 Engine from a 1994 Acura Integra 5 Speed. It is a long block with the cylinder head complete to the valve cover, Intake manifold and Injectors, with throttle body but the throttle position sensor is broken, Exhaust manifold with heat shields, Alternator brackets, A/C Bracket, Lower Power Steering Pump Bracket, O2 Sensor, Oil Pan, Fly Wheel, Oil pump, crank shaft pulley and timing belt. The Engine has 150,000 miles on it, I heard it run before I pulled it, It came from a friend’s car that was rear ended. The engine stand is also going with it. I have a starter and alternator for this engine as well; just they are not mounted on it.
Second I have a complete clutch for this engine with two clutch plates one for the new style transmissions and one for the older style transmissions.
Third I have an American 5 speed manual transmission from a 1990 Acura Integra, it is complete with the clutch fork and release bearing and reverse light switch and some of the mounts. The trans has 175,000 miles on it, it may need a syncro for 5th gear like they all do with age, I have some extra syncros I can throw it but it drove fine otherwise.
I have a complete exhaust system, A pipe, catalytic convertor, B pipe and muffler that came out of my 1990 4 door Acura Integra, It is in good used condition, no holes or leaks, I simply do not need it anymore. The B Pipe and the Muffler are about 6 years old, I replaced them myself. Good news is that if you have a four door you can just shorten the b pipe to make it fit, all of the other parts are the same from the factory.
I have a complete cylinder head from a B18A1 engine and I have the complete intake manifold for that same engine. The head is complete to the valve cover and the intake manifold has the wire harness and all of the sensors and fuel injectors the fuel injector resistor and the throttle body.
I have a factory intake manifold from a 1995 VTEC engine, it is just the all bolted together with the butterflies and the fuel rail and the vacuum accessories to operate the butterflies, no throttle body or fuel injectors.
I also have a second B18A1 manifold with some parts on it, the fuel injectors EGR valve and some of the vacuum lines, it does not have the throttle body on it.
There is an OBD0 distributor included here.
A pair of air intake hoses that are from 1990 – 1993 Integra’s are included.
Two working OBD0 computer from 1990 Acura Integra 5 speed cars are going to go in this lot of parts, I drove cars on these computers and they work fine.
A good radiator from a 1990 Acura Integra with upper and lower radiator hoses and the main cooling fan are also included here with everything else.
There are lose parts from a B18A1 engine, a set of rods and pistons, the rods are good and straight and the pistons are useable if you have an engine that needs them. The oil pump and the rear engine seal housing are here and in good working order. There are two oil pans from the B18A1; one is good with the pick-up tube and windage tray and hardware, the other has a stripped oil plug hole and can be repaired by a talented welder.
The front anti-sway bar from a 1990 Acura Integra is included in this lot.
If you want to see more pictures contact me with your e-mail address and I will e-mail you a zip file with the pictures I have. If you have questions about the parts I will do my best to answer them, Thank you for looking.
Last edited by mocchiuto; Oct 31, 2010 at 05:49 PM. Reason: Parts now for sale separately.
Old Oct 24, 2010 | 12:45 PM
Mr. Bubble's Avatar
Default Re: F/S Acura Integra B18B1 Engine, Transmission Exhaust System and More
Do u have an oem cat converter?? Pm me
Old Oct 25, 2010 | 04:23 AM
mocchiuto's Avatar
No, good luck.
Old Oct 26, 2010 | 12:47 PM
mocchiuto's Avatar
New Bump Thanks
Old Oct 28, 2010 | 06:21 PM
mocchiuto's Avatar
Thursday Bump, Thanks
Old Oct 31, 2010 | 05:48 PM
mocchiuto's Avatar
Parts now for sale separately, Thank you
Old Nov 5, 2010 | 04:50 AM
mocchiuto's Avatar
Weekend Bump, Thanks.
Old Nov 7, 2010 | 11:29 AM
mocchiuto's Avatar
Transmission has sold separately, now taking offers on the remaining parts, Thank you.
Old Nov 12, 2010 | 04:02 PM
blackGSRcoupe94's Avatar
how much for the bottom end, PM with price. thanks
Old Dec 4, 2010 | 03:46 PM
EKBlkicex's Avatar
How much do you want for the motor? text me at 301-466-9032 very interested.
Old Dec 10, 2010 | 10:12 AM
mocchiuto's Avatar
Default Sold Please remove
It has been sold, thanks
Old Feb 19, 2011 | 03:25 PM
hawaiiacura's Avatar
Default Re: Sold Please remove
how much for the cylinder head please call me with price 808-333-8969 matt
Old Feb 19, 2011 | 03:56 PM
mocchiuto's Avatar
Parts have been sold, thanks.
mocchiuto's Avatar
Default SOLD
SOLD
revemoto
Oct 6, 2010 04:01 PM
brx017
Mar 4, 2009 07:33 PM
brx017
Southeast (Sales)
13
Danronian
Northeast (Sales)
Jan 3, 2006 01:43 PM
Danronian
Jan 3, 2006 01:42 PM
