jdm swap from h23 to a f22b
Old Oct 24, 2010 | 10:27 AM
racerrick's Avatar
Default jdm swap from h23 to a f22b
ok here we go 92 prelude with a jdm motor and a us harness. ended up with 2 extra wire connectors.1 is green 2 wire in the dist harness.the 2nd is on the pass strut tower and is gray 2 wire.the fans do not come on and the check engine light is on.is there a way to pull codes with out a scan tool?
does any one have a vacuum hose routing chart? thanks for any help you can give us
Anthony Mccook
Jan 16, 2016 07:11 PM
accuder
Feb 11, 2007 07:08 PM
92inprogress
Apr 11, 2005 08:22 AM
Maximo
Aug 22, 2002 05:54 AM
