Steering Problems Need Help ASAP!!
Old Sep 20, 2002 | 12:04 PM
cybspur's Avatar
Default Steering Problems Need Help ASAP!!
Before I get flamed, I did do a search, and nothing that fits my description came up so....I just changed my tie rod ends, left and right, because after research and talkin to peeps, they say that it might fix my problem(which it did not), which is: My steering wheel is loose. Whenever I hit a bump, my steering wheel will turn to the left or right depending on which wheel hit the bump. Also in order to go straight the steering wheel has to be turned abit 'O ways to the right
(95-100 degrees?). Also if I let my hand off the wheel while the car is moving the steering wheel will start turning to the right. Ok, hope yall can help while I got the car jacked up. Thanks
Old Sep 20, 2002 | 12:05 PM
cybspur's Avatar
Default Re: Steering Problems Need Help ASAP!! (cybspur)
Oh I got a 1990 Civic EX....
Old Sep 20, 2002 | 02:33 PM
Doodoo's Avatar
Try checking if the steering rack has all the bolts still in it. Mine lost 2 closest to the steering wheel and it felt like driving a big rig. It just kept turning and turning.
Danielsb20crx
39
Jan 6, 2013 01:02 PM
^^ gökan^^
Suspension & Brakes
Jan 31, 2010 11:53 AM
theeogflip
May 22, 2007 11:28 AM
