89 Sedan build
Old Oct 23, 2010 | 03:11 PM
gnxpro24's Avatar
Default 89 Sedan build
I want to do a motor swap in my 89 sedan. The two choices I have it narrowed down to are a D16Y8 and a B18b. If i go with the B18b, i will not use premium gas which will drop the power. B18b=140 horsepower minus prob. at least 10 for lack of right gas. D16Y8=127 horsepower. B18b is $250 and lots of $ for swap parts. D16Y8, I will need to find. Opinions please!
Old Oct 23, 2010 | 03:16 PM
StayKrafty's Avatar
Default Re: 89 Sedan build
More power to be had with the b18b. It does NOT require premium gas, but I dont see the reason no to use it. One thing the B18 has that the D16 doesnt it torque.
Old Oct 23, 2010 | 03:19 PM
gnxpro24's Avatar
If I keep either engine stock and dont use premium, I'll end up with better gas mileage and power with the D16Y8 and you can always turbo either of them
Old Oct 23, 2010 | 03:21 PM
StayKrafty's Avatar
Actually, premium gas either way will give you better gas mileage in the long run.
Old Oct 23, 2010 | 03:23 PM
gnxpro24's Avatar
the Teg only got 22-30 I believe and the sohc 1.6 usually gets in the 30s even in town
Old Oct 23, 2010 | 03:26 PM
StayKrafty's Avatar
If you're worried about gas, then I wouldnt be swapping it.
Old Oct 23, 2010 | 03:27 PM
gnxpro24's Avatar
Why? the d16Y8 has 35 more horsepower and Vtec and still gets great mileage
Old Oct 23, 2010 | 03:30 PM
StayKrafty's Avatar
If you're worried about vtec, then it sounds like you're going to beat on it. See how gas mileage does after that.
Old Oct 23, 2010 | 03:35 PM
gnxpro24's Avatar
What do u mean? Vtec is just a better setup. Good mileage, then power when u need it. What is your definition of beating on the engine? Driving/accelerating fast? If so, no duh
Old Oct 23, 2010 | 03:44 PM
StayKrafty's Avatar
From personal experiences, when someone wants "vtec" its usually a kid thinking its going to make his car much faster than it will. That being said, the B18B will put down more power regardless. You wont notice vtec in the Y8 at all. When I had a B18 in my EF hatch, I was still getting 30 miles to the gallon. The reason the teg doesnt get so high in the mpg, is its weight. Much heavier than what my hatch was.
Old Oct 23, 2010 | 03:47 PM
gnxpro24's Avatar
Well yes I'm 17 and I like the vtec for extra power and speed as well. And I can't believe I never thought of the weight thing for mileage haha I usually associate it with speed. What do you think you could pull of in town with the b18 in an 89 sedan (bout 2300 pounds)
Old Oct 23, 2010 | 03:50 PM
StayKrafty's Avatar
Well, depending on driving habits, mileage and condition of motor, Im sure you could easily get around 25-30 no problem. Ive seen others get better on a good tune.
Old Oct 23, 2010 | 03:56 PM
gnxpro24's Avatar
in town? that would be great but I'm sure I'd get worse because I'd always be gunning it on acceleration
It's an argument with myself right now because depending on how much I can find a d16Y8 for it might be the same or cheaper than a B18b after you buy all the aftermarket swap parts, and like i said I'm not into premium so that would probably kill my power and mileage?
also would u get better mileage with a D15b2 trans or a B16, probably D15 but a hell of a lot slower
Old Oct 23, 2010 | 04:02 PM
StayKrafty's Avatar
B16 trans on the b18 will lower the mileage at highway driving due to the higher gearing. Premium gas burns cleaner than lower octane gas causing increased gas mileage. The B18 more most likely cost more in the long run to have it working in your car just because theres more youd have to buy. Personally, Id go with the b18b. It'll give you more power, but the low end torque is nice.
Old Oct 23, 2010 | 04:06 PM
gnxpro24's Avatar
So actually by using premium you could make up for some of the extra cost of the premium cause you would be getting better mileage?!
Old Oct 23, 2010 | 04:12 PM
StayKrafty's Avatar
Yeah, I look at this way. If I use 10 gallons of gas, and I fill it up with 10 gallons on premium gas, I'm only spending $2 more for every fill up. I've noticed that im reaching upwards to 40mpg highway and city combined.
Old Oct 23, 2010 | 04:15 PM
gnxpro24's Avatar
wow! that would be awesome, too bad u can't get 40mpg highway like the d15b2 haha but that's good. Do u have any videos of your car driving? Also have you done any upgrades or is this all happening due to it being stock?
Old Oct 23, 2010 | 04:19 PM
StayKrafty's Avatar
Well with my current car, its a jdm d15b, with all the basic bolt on's. Get pretty good gas mileage all around.
Old Oct 23, 2010 | 04:22 PM
gnxpro24's Avatar
I thought u were running the b18? which one gets the 40 mileage between city and highway??
Old Oct 23, 2010 | 04:25 PM
StayKrafty's Avatar
d15b does. I had an LS in my old civic hatch, driving a crx now. When I had the LS, I was getting 30 city/highway combined. That was due to me using the gsr trans (driving at 60mph I was at or around 4000RPM, that will be a gas killer)
Old Oct 23, 2010 | 04:27 PM
gnxpro24's Avatar
which translates to what in a 2300 pound sedan with added b18 engine weight but a d-series trans which happen to be great on gas, aha
Old Oct 23, 2010 | 04:37 PM
StayKrafty's Avatar
Not sure, I would assume close to the same mpg. Are you talking about using a d series trans on the b18? You could use a longer geared LS trans.
Old Oct 23, 2010 | 04:45 PM
gnxpro24's Avatar
yea i mean the stock d15 trans. already bought one and the Teg I'm getting the engine from is an auto.
Old Oct 23, 2010 | 04:48 PM
gnxpro24's Avatar
btw do u happen to have ne of the necessary swap parts for the 88-91? and/or a list of all the parts I need.
Old Oct 23, 2010 | 04:53 PM
StayKrafty's Avatar
For the teg, a PR4 ecu, 90-93 axles, motor of course and mounts. After seeing your build thread, youll also need to convert to MPFI. Also, you'll need shift linkage and an si harness
