h22 dohc vtec
Old Oct 22, 2010 | 09:24 PM
jojo ethan's Avatar
Default h22 dohc vtec
is a 92 h22 vtec the same as a 98 h22 vtec
Old Oct 23, 2010 | 06:10 AM
TheMuffinMan's Avatar
He knows where you live!
Default Re: h22 dohc vtec
Way too vague
H22A? H22A1? H22A4? JDM? USDM?
Old Oct 23, 2010 | 11:38 PM
joe_accord23's Avatar
wut???
Old Oct 24, 2010 | 06:37 PM
AlmostJDM's Avatar
engine wise for the most part yes, except for a few little things internally like main bearings, they are bigger on the 98, electrical wise no, the 92 is obd1 and the 98 is obd2
Old Oct 24, 2010 | 07:20 PM
Akkord2k1's Avatar
yep, pretty much
Old Oct 25, 2010 | 12:42 AM
and jdm h22 have higher compression ratios than the usdm spec.
Old Oct 25, 2010 | 12:49 AM
AngryAgent's Avatar
Would the 92+ USDM H22 head be good to use for the G23 engine build with the F23A1?
And if the bearings are larger in the 98 can the 92 be modified to be the same?
h22turbocivic4dr
Apr 25, 2004 10:03 AM
h22turbocivic4dr
Apr 23, 2004 02:00 PM
ExAcc
Jun 15, 2002 03:45 AM
