1999 GSR Sedan Build.....Very Mild..........
Well, I picked up a 99 GSR Sedan very clean with a blown engine (broken block #1 cyl) at the auction for dirt cheap and have already peeled off the front end and taken the entire drive train out. Ordered a ITR front clip and got that already. Planning on RHD conversion and front end swap. Had to test my new motor last night, just hooked up a fuel source at the lines that were cut and cranked it over. Check it out........
http://www.youtube.com/v/v2oqg7GfDCo
Added 2009 Civic SI Seats (Front & Rear), car came with Tein Springs and KYB GR-2 shocks, Very little 1/4 panel rust. Anyone looking to buy a GSR trans or cyl head, or Gray Leather Seats??
I'm sensing a lot of scarsam in the statement "Very Mild." And why are the gr-2 shocks bad? I have yet to have any problems with mine. Knock on wood. Lol
And yes, I mean a mild build (to me anyways.......).............don't believe all the stories about how RHD firewall swaps are hard.........The only hard part is going to be extending the wiring for the rear portion of the car, and that's where the wiring diagrams come in handy..........splice, solder and shrink wrap.......to some the swap might be considered "hard" but if you take your time and you know what you are doing, then it's not all that bad............
Ahh good point. Ill rock them till they blow then replace everything with a koni/ground control setup. I couldnt afford it when I needed to replace suspension parts so I just used the kyb's and h&r lowering springs that I could afford.
My Koni Sport shocks have nearly 200K miles on them, always lowered (some of that time on GC's), still work great. You probably would go through at least 4 or 5 sets of GR-2's in that amount of time.
14eight
Oct 26, 2006 07:07 AM
turbotime
May 11, 2005 10:07 AM
