DA integra clutch pedal assemble bolt in to ef?
i was just wondering if a DA integra clutch pedal assembly would fit into a ef? is it a direct bolt in or do i have to custom some stuff to make it fit? i heard it does fit, but wasn't sure...any info or pictures would be helpful. thanks in advance.
you know lots of parts are interchangeable with hondas. and im sure the pedals will work. but how well they work is the main question. personally i would not try to do that.but different people will have different opinions. like putting a da dash into an ef. yeah people have done it but i think it looks like as$. haha. i once broke my clutch assembly on my 90 hatch. i pulled a 90crx assembly and to my surprise it did not look identical so i did not buy it. my advise would be to find the correct year vehicle and use it. good luck .
I've never TRIED to install one, but judging off of seeing the two, I would think it does, they have a different design to them, but the part that bolts to the car appears to be the same in terms of shape and mounting points.
main difference in the ef and da pedal assemblies is the weighted clutch pedal as well as it is reinforced in the area where the ef pedals commonly snap.
