Anyone DD with a traction bar in their EF? CRX, Wagon, Hatchback, Sedan----POST UP!
Old Oct 21, 2010 | 06:46 PM
JDM_rolex's Avatar
Default Anyone DD with a traction bar in their EF? CRX, Wagon, Hatchback, Sedan----POST UP!
Do you DD with a traction bar?
What suspension set-up do you have?
What brand is it?
Hows the ride comfort with them?
How was hard was it to have the shop do an alignment on your Vehicle?
How is it Holding up now?
Where do you jack up your vehicle?
**New question**
How low does your traction bar hang? Full-Race, ETD, Innovative which one is lower?
POST PICTURES PLEASE!
Old Oct 21, 2010 | 08:40 PM
JDM_rolex's Avatar
Default Re: Anyone DD with a traction bar in their EF? CRX, Wagon, Hatchback, Sedan----POST U
No one??? this cant be..
Old Oct 21, 2010 | 09:34 PM
same ol Steve's Avatar
1. 91 Civic Si
2. H&R Sport springs and Koni Yellow shocks
3. Full Race
4. Rides is great,but a little noisier than stock
5. No problems getting alignment
6. Been on the car for 2+ years no issues
7. Jack it under the tow hook brackets
Pictures soon as I can
Old Oct 22, 2010 | 09:15 AM
rbjeepthing's Avatar
What brand is it?
1. Yes however it's an Innovative Replacement Front Crossmember (Better then the factory one not as adjustable as a full traction bar)
2. Teins on KYB' GR2's
3. Innovative
4. Minty Fresh
5. You can't adjust
6. Minty Fresh
7. Same as before
Pics:
Old Oct 22, 2010 | 09:45 AM
.Manny.'s Avatar
Touching My Member
-I DD with an Innovative Traction Bar
-Koni/GC w/ Extended Top Hats 400F/500R Springs
-Feels a lot more solid, A bit more noise but normal for having metal instead of rubber
-Inline4 did my alignment, they had no problem at all
-Had it on a few months, holding up great!
-Jack it up under the Tow Hooks
Old Oct 22, 2010 | 04:36 PM
JeffBro's Avatar
bump I wanna see some trac bars too. Thinking about fabricating my own bar but I wanna see more designs so I can get more ideas
Old Oct 26, 2010 | 04:13 PM
JDM_rolex's Avatar
TTT, this stuff can really help a lot of ppl out. Thanks to the guys that have posted!
Does the wheel hop still happen when launching hard?
Old Oct 26, 2010 | 05:53 PM
GroundZer0 336's Avatar
PIC select's 12/10k
ETD
not much different than stock really, just more solid feeling, prob. is noisier but its been so long since ive had stock suspension...
aligned it myself at work, super easy. only thing is it hangs really low, and we have lifts in the middle of the alignment rack, i had to take them off, which was a bitch!
its been holding up fine, its been on 2 dif. cars for 2 years and havnt had any problems
jack it under the tow hook points usually
might can find a pic that shows it i will post it up if i can find it
Old Oct 27, 2010 | 04:55 AM
EJ1_Sleeper's Avatar
1) Do you DD with a traction bar?
2) What suspension set-up do you have?
3) What brand is it?
4) Hows the ride comfort with them?
5) How was hard was it to have the shop do an alignment on your Vehicle?
6) How is it Holding up now?
7) Where do you jack up your vehicle?
1) Yes
2) Dropzone 500f/450r coil and KYB AGX shocks
3) Homemade/fabbed
4) Its noisy and clanky since its spherical links and not rubber bushings
5) Alignment was no problem, easily adjustable
6) It came loose once (bolts at tow hook location), but I'm fabbing another to use both oem location and stock tow hook (hasn't come loose since retighetning)
7) The tow hook locations, sometimes even rest the stands on it on both sides.
Will post pics later
Old Oct 27, 2010 | 11:39 AM
Vagitarian's Avatar
Ive had my ETD on a turbo d16 for 3-4 years now, works flawless, powdercoat held up amazingly still shines
315whp
Old Nov 2, 2010 | 06:49 PM
JDM_rolex's Avatar
Which brand would you guys suggest? Full-Race, ETD, Innovative?
Old Nov 2, 2010 | 08:41 PM
EFfective's Avatar
-yes
-tokico blues with eibach springs
-z10 clone built by me using z10 radius arms
-ride is decent, handling is good
-i do my own alignments and its actually easier with the traction bar installed because of the addition of a caster adjustment
-its been on there for about a year and a half and its just as tight today as it was the day i installed it
-i jack it on the steel plates on the left or right side
-ground clearance could be better but i'm on 13's and its still higher than my header
Old Nov 2, 2010 | 08:51 PM
michael O's Avatar
What brand is it?
1. Yes
2. Tokico Illuminas/GC
3. Jimfab
4. Smooth and buttery
5. Easy
6. Great
7. Middle of the Traction Bar
8. Basically stock location
Don't have pictures.
Old Nov 4, 2010 | 11:13 AM
JDM_rolex's Avatar
Thank you for the input everyone!
Hopefully more people shine some light on this topic!
Old Nov 4, 2010 | 06:27 PM
zrickety's Avatar
-yes. going on 4 years
-tein basic coilovers
What brand is it?
-full race
-long road trips suck, but i think it's the driver's seat more than suspension. other than that, very comfortable...and turns like it's on rails! no wheel hop.
-no problem. i set the traction bar caster to stock length, they said it was good
-i lube the joints once in awhile, holding up fine
-i use stock locations by the wheels, never have used the crossmember
-the bar is not too low, it's the tow hooks that scrape coming out of driveways
Old Nov 9, 2010 | 04:35 PM
JDM_rolex's Avatar
More posts! please?
Old Nov 9, 2010 | 05:09 PM
JeffBro's Avatar
I like that setup EFfective. That does have good clearance. lol @ header thats low...
Old Nov 9, 2010 | 05:19 PM
tuck1crx's Avatar
do the EDT's rub at all?
Old Nov 10, 2010 | 05:14 AM
Bigdavebrooks's Avatar
i daily drive my hatch with innovative mounts compation traction bar i really like it well worth the money
Old Nov 10, 2010 | 07:05 AM
ef92b's Avatar
yes. 4+ years and goin in one of my ef hatch(grey) and almost 2 years with the other hatch(blue).
GC/Koni Yellows on both cars. 450F/350R and 450F/500R
What brand is it?
both kits from Full Race
i love it when stiff LOL i've been used to with a stiffer suspension even before having my trac bar/s so no big deal. great when launching, high speeds and sudden braking.
very easy, peanuts specially with the caster part.
same as day one, however, it starts to rust a bit next to the tow hooks (welded brace below the round bars). salty water i guess from where i live.
mostly at the middle of the bar but using a 1/2 inch rubber padding or insert between the bar and the jack plate.
tucked. my PJDM CF lip hangs lower and gets most of the scratches
closest pic i have:
Old Nov 10, 2010 | 07:25 AM
tuck1crx's Avatar
any1 runna a traction bar on a 92-95 civic??
Old Nov 10, 2010 | 03:27 PM
JDM_rolex's Avatar
ef92b- Thats exactly what I am looking for! Thank you!
TTTT
Old Nov 10, 2010 | 04:03 PM
thatHEMIguy's Avatar
my Full Race traction bar just came in the other day. Im just waiting till pay day to get the half size rad (so i can fit my turbo). Ill be running tein springs on Skunk2 struts
Old Nov 11, 2010 | 03:28 PM
JDM_rolex's Avatar
Mods should sticky this to help out on the Traction bar questions!
Old Nov 12, 2010 | 08:29 PM
tuck1crx's Avatar
i guess no1's runnin on a 92-95??
