*HELP* Rear Toe Issues
Old Oct 21, 2010 | 06:12 PM
JDMchucko's Avatar
Default *HELP* Rear Toe Issues
I posted this on EF-honda too.
I have a 89 hatch, just completed a DA rear disc swap. Now my rear toe is very negative (sticks out in front) and wanders at higher speeds due to this.
Heres the Facts
1: I used my civic LCA's, UCA's and Toe links
2: trailing arms are off a 2door 90-91 DA
3: I pressed the worn trailing arm bushings for energy suspesion bushings
I did a alignment just now, I brought rear toe in as much as I could, now its LEFT (-.90) and RIGHT (-.055) camber is even side to side (-3.9)
I did notice the DA toe links are much shorter, Do I need to use these and NOT the civic ones? They seem to be about 1" shorter.
I also noticed one of my DA toe sleeves is bent, So Am I using the wrong toe sleeves or are my trailing arms bent?
Has anyone ran into this? Thanks in advance.
Old Oct 21, 2010 | 06:16 PM
BiG ChOr!Zo's Avatar
Default Re: *HELP* Rear Toe Issues
anything bent is not good...also use a ef toe link and not a da one...!!!
Old Oct 21, 2010 | 07:29 PM
asianflava's Avatar
I did the same exact swap about a month ago and it aligned perfectly. I did replace my links (toe and camber) with adjustable links.
Old Oct 21, 2010 | 07:52 PM
donaldmejr's Avatar
I've done the same swap (all from a DA) But I also replace my toe and camber links with adjustable ones
Old Oct 21, 2010 | 07:53 PM
donaldmejr's Avatar
Wicked tuning I think is the brand I used....Seem good
Old Oct 21, 2010 | 08:09 PM
JDMchucko's Avatar
Thanks for your input guys, was your guy's toe out before the adjustable links were put on? Is this considered normal to have to put adjustable toe links on?
Also, I just did a quick search. I looked at the wicked arms. MSRP is $250, Ksport has them for about $100.
Do I need to get them for a DA or for a EF (adjustable toe arms)
Thanks again
Old Oct 21, 2010 | 08:13 PM
donaldmejr's Avatar
I did everything aftermarket suspension wise that you could do so everything was off.
Old Oct 21, 2010 | 09:43 PM
Tyson's Avatar
what is a "DA toe sleeve"?
Old Oct 22, 2010 | 07:23 AM
JDMchucko's Avatar
Sorry, Integra DA Toe compensator arm.
Old Oct 24, 2010 | 10:04 PM
JDMchucko's Avatar
*bump*
Any other thoughts?
Old Oct 24, 2010 | 11:46 PM
0_civic_4's Avatar
if you have almost negative 4 degrees of camber you wont be able to get your toe correct without aftermarket toe arms
Old Oct 25, 2010 | 04:43 PM
JDMchucko's Avatar
Ordered Adjustable toe links today. I will post results when installed.
Thanks!
drsab2000
12
Oct 31, 2013 09:39 AM
r_arraz
Suspension & Brakes
Nov 28, 2012 12:40 PM
wannaBjdmca6
Suspension & Brakes
26
Jan 16, 2011 08:24 PM
beana
Jan 4, 2010 02:08 PM
dng
May 25, 2004 07:29 AM
