FS: 1989 CRX HF Needs LOVE, Not a Show car
Old Oct 21, 2010 | 04:41 PM
TYPEcRx's Avatar
Default FS: 1989 CRX HF Needs LOVE, Not a Show car
For Sale: 1989 Honda Civic CRX HF with 117,xxx miles Clean Title
Asking Price: $1,600 OBO **No Trades** ** Cash Only**
Engine:
Mini- Me
Short block: D16Y7 150, xxx miles
Head: D16Z6 130, xxx miles with 1990 CRX SI Intake Manifold
Transmission: 1990 CRX SI L3 5speed
New Excedy Stage 2 Clutch
New Pilot Bearing
New Intake Manifold Gasket
New Head Gasket
New Oil Pan Gasket
New Timing Belt
New Water Pump
New Timing Belt Tensioner
New Distributor Cap
New Rotor
New Spark Plugs
New Spark Plug wires
New Valve cover gasket
New Upper Radiator Hose
New Lower Radiator Hose
New Rear Main Oil Seal
New Thermostat
Fresh Oil Change with Mobil 1 5w-20 Full Synthetic with OEM Honda Oil Filter
New Honda Manual Transmission Fluid
New Both Front Axles
New Right Outside Tie Rod ( Steering wheel is a not straight driving down the road due to replacing this and the vehicle is in need of a front end alignment)
VTEC is wired up
4wire O2 is wired up
Check Engine Light jumper wires is hooked up to a switch under the glove box
Xenocron OBD0-OBD1 Jumper Harness
OBD1 PO6 with a Stock p28 base map from Xenocron
Xenocron Distributor Adapters
1990 CRX SI Front Hubs, Knuckle, Rotors, Calipers
Ebay Intake (its actually the same size as the throttle body)
Ebay Headers
2.5 High Flow Cat Converter ( Not ebay )
2.5’’ Custom Crushed exhaust system to an actual muffler( Nice and quiet)
Suspension:
All stock EXCEPT Front Tower Strut Bar (not shown in pics but is included)
Chasis:
117,xxx miles
Does has the usual rust spots but no holes yet
Moonroof
*Driver side front area was backed up into by a truck 4-5 years ago. No insurance so no report ( *see pics)*
*Washer tank is still there but the washer fluid pump doesn’t work*
*Left front corner light turn signal doesn’t work*
*No windshield squirters*
*Left front fender has been replaced and repainted and now starting to peel*
*No hood latch cable*
*No left front fender liner*
*Window track is sloppy* Typical*
Has a Viper Keyless entry alarm
New Walbro 255hp Fuel Pump
NO CRACKS IN WINSHIELD!
Hatch struts still hold up
2 tires in the Front are Pratically brand NEW
2 tires in the rear have camber wear
All 4 matching Fuzion HRI tires
Have the center cover in the garage for the Rims
** These tires used to be on my B16 CRX and the pervious owner never rotated the tires and slammed the B16 CRX**
Battery relocated to the rear * Has a bigger battery also* *Wal-Mart*
Can be hooked up the a switch ( For race purposes only)
Race switch is located in the rear key hole
Has Pioneer 3 way 6x9 in the rear
Has Bose speakers in the front
Radio harness was been spliced but its guaranteed to work. It did have a working CD Player in there
Can include 6K HID KIT at NO CHARGE
1988 CRX SI Front Driver Seat
Black CRX SI Glove Box
I also have blue 1993 Prelude bucket type seat at no charge if you want it
1993 Honda Climate control I have everything hooked up and functioning.
-All the modes work ex. Feet, face and feet, defrost and feet etc, etc
-Both recirc and Fresh air mode does work
-All fan speeds work
-* you will have to redo the hot and cold part. As it sits right now all the way cold on the climate control is at ALL THE WAY HOTT!
-Does not have the cold cable in the car (I shortened the cable too short so right now its set on close due to winter)
Missing Rear Interior Pieces as you can see in the pictures
Any other ?’s or comments Just call or text me at 920-819-5137
Pictures
Old Oct 21, 2010 | 04:43 PM
TYPEcRx's Avatar
Default Re: FS: 1989 CRX HF Needs LOVE, Not a Show car
http://i254.photobucket.com/albums/h...e/100_2239.jpg
http://i254.photobucket.com/albums/h...e/100_2238.jpg
http://i254.photobucket.com/albums/h...e/100_2237.jpg
http://i254.photobucket.com/albums/h...e/100_2236.jpg
http://i254.photobucket.com/albums/h...e/100_2226.jpg
http://i254.photobucket.com/albums/h...e/100_2225.jpg
http://i254.photobucket.com/albums/h...e/100_2224.jpg
http://i254.photobucket.com/albums/h...e/100_2223.jpg
http://i254.photobucket.com/albums/h...e/100_2222.jpg
http://i254.photobucket.com/albums/h...e/100_2221.jpg
http://i254.photobucket.com/albums/h...e/100_2220.jpg
http://i254.photobucket.com/albums/h...e/100_2219.jpg
http://i254.photobucket.com/albums/h...e/100_2209.jpg
http://i254.photobucket.com/albums/h...e/100_2208.jpg
http://i254.photobucket.com/albums/h...e/100_2207.jpg
http://i254.photobucket.com/albums/h...e/100_2206.jpg
http://i254.photobucket.com/albums/h...e/100_2205.jpg
http://i254.photobucket.com/albums/h...e/100_2204.jpg
http://i254.photobucket.com/albums/h...e/100_2202.jpg
http://i254.photobucket.com/albums/h...e/100_2229.jpg
http://i254.photobucket.com/albums/h...e/100_2228.jpg
http://i254.photobucket.com/albums/h...e/100_2216.jpg
http://i254.photobucket.com/albums/h...e/100_2215.jpg
http://i254.photobucket.com/albums/h...e/100_2213.jpg
http://i254.photobucket.com/albums/h...e/100_2212.jpg
http://i254.photobucket.com/albums/h...e/100_2211.jpg
http://i254.photobucket.com/albums/h...e/100_2210.jpg
http://i254.photobucket.com/albums/h...e/100_2252.jpg
http://i254.photobucket.com/albums/h...e/100_2251.jpg
http://i254.photobucket.com/albums/h...e/100_2235.jpg
http://i254.photobucket.com/albums/h...e/100_2234.jpg
http://i254.photobucket.com/albums/h...e/100_2218.jpg
http://i254.photobucket.com/albums/h...e/100_2217.jpg
http://i254.photobucket.com/albums/h...e/100_2250.jpg
http://i254.photobucket.com/albums/h...e/100_2249.jpg
http://i254.photobucket.com/albums/h...e/100_2248.jpg
http://i254.photobucket.com/albums/h...e/100_2247.jpg
http://i254.photobucket.com/albums/h...e/100_2245.jpg
http://i254.photobucket.com/albums/h...e/100_2244.jpg
http://i254.photobucket.com/albums/h...e/100_2233.jpg
http://i254.photobucket.com/albums/h...e/100_2232.jpg
http://i254.photobucket.com/albums/h...e/100_2231.jpg
Old Oct 21, 2010 | 04:45 PM
TYPEcRx's Avatar
Is there a way to add more pics onto another thread under this post?
Old Oct 21, 2010 | 05:30 PM
TYPEcRx's Avatar
Bump! Buy this thing! its OBO!!!
Old Oct 21, 2010 | 06:44 PM
ehybeech95eg's Avatar
bump for a crx
Old Oct 22, 2010 | 06:28 AM
TYPEcRx's Avatar
Bump ! I know someone needs a winter beater!!! Remember it's OBO!!!!
Old Oct 24, 2010 | 02:48 PM
TYPEcRx's Avatar
Bump! PM's REPLIED!!!
Old Oct 25, 2010 | 04:15 AM
gsrlee's Avatar
damn..... bump for you dude.... u should know who this is... ahahaha!
Old Oct 26, 2010 | 05:56 PM
TYPEcRx's Avatar
gsrlee- I know who you are. I havent seen you in ages.
Who needs a winter beater? Come on people!!!
Old Oct 27, 2010 | 05:50 PM
TYPEcRx's Avatar
BUMP! Damm you flakers!
Old Oct 28, 2010 | 05:00 PM
TYPEcRx's Avatar
Bump!
Old Oct 29, 2010 | 03:56 PM
TYPEcRx's Avatar
Bump!
Old Nov 1, 2010 | 05:13 PM
TYPEcRx's Avatar
Bump!
Old Nov 2, 2010 | 05:01 AM
leftwal2's Avatar
I would give u 400.00 for the motor
Old Nov 2, 2010 | 04:51 PM
TYPEcRx's Avatar
$400? Text me at 920-819-5137 and we'll talk more
Old Nov 7, 2010 | 06:08 PM
TYPEcRx's Avatar
Bump for a straight up beater!
Old Nov 11, 2010 | 05:38 PM
TYPEcRx's Avatar
Bump!
Old Nov 12, 2010 | 06:33 PM
TYPEcRx's Avatar
Bump! I know someone needs this beater.
Old Nov 15, 2010 | 04:33 PM
TYPEcRx's Avatar
BUMP!!!
Old Nov 15, 2010 | 07:23 PM
kozanatos's Avatar
rex with not a super amount of rot delicious
Old Nov 16, 2010 | 05:45 PM
TYPEcRx's Avatar
Bump!
TYPEcRx
Dec 10, 2007 02:58 PM
mykoe817
Jul 20, 2007 11:24 AM
DrakeMK3
May 7, 2006 05:17 AM
DrakeMK3
Southeast (Sales)
May 7, 2006 05:16 AM
Count Blah
Dec 15, 2002 11:16 AM
