Hard to shift?! Help!
Old Oct 21, 2010 | 03:17 PM
DC2_ALL MOTA's Avatar
Default Hard to shift?! Help!
Okay so I was driving around and decided to get on it and when I went to shift hard to 2nd and she wouldn't go in gear. I thought I just missed shift, but I never do. After that happend she wouldn't go into gear. I pumped the clutch pedal a few times then she went into gear finally. Ever since that happend, it's kind of rough to go into gears unless I'm shifting at low rpms then it shifts fine in all gears. It's even harder to downshift unless I'm going real slow and pump the clutch. The clutch feels still good and grabs good. I changed out the slave cylinder and bleed it numerous times, but same results. I don't hear any weird noises either. My buddy told me to try and new clutch master cylinder. What do you guys suggest? Oh my car is a 99 gsr teg with jdm gsr swap.
Old Oct 21, 2010 | 03:37 PM
Default Re: Hard to shift?! Help!
Oh and transmission fluid and level is good.
Old Oct 22, 2010 | 05:22 AM
anybody?
Old Oct 22, 2010 | 05:37 AM
dntnedvtec's Avatar
Have you had the tranny rebuilt?
The clutch pedal firm?
Shift linkage hooked up correctly?
Old Oct 22, 2010 | 12:35 PM
1998GsRIntegra's Avatar
Had the same problem with my 98 gsr. You need a new clutch disc and pressure plate. My clutch came out in pieces when I replaced it. Lol
Old Oct 22, 2010 | 01:06 PM
EHondaJDM's Avatar
X2
-Could be clutch
-Could be bad shift linkage bushings
-Could be the synchros in ya tranny
Old Oct 22, 2010 | 01:10 PM
Tranny is stock with about 100k and shifted smoothe in all gears, so I don't think the tranny is messed up or the synchros. Clutch pedal does feel alittle softer. Checked the linkage and its hooked up correctly.
Old Oct 22, 2010 | 04:37 PM
EHondaJDM's Avatar
Bleed clutch line
Old Oct 22, 2010 | 06:33 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Yep, you busted a clutch disc spring or part of the metal surrounding one or more of the springs. Happened to me on my original clutch at 135K after a hard run to red line in 1st and 2nd gear.
Old Oct 25, 2010 | 05:01 AM
Feels like clutch still grabs good tho, and I dont hear any clacking or grinding noises. Im goin to try a new clutch master cylinder 1st.
Old Oct 25, 2010 | 05:10 AM
fcm's Avatar
fcm
Old Fart
A damaged clutch spring or bent finger(s) would not prevent clutch from "grabbing good" it prevents proper disengagement, replace the clutch. 94
Old Oct 25, 2010 | 07:49 AM
Community Builder
Exactly - I didn't have any symptoms other than hard to shift before I replaced my original clutch. Pulled it out and found broken metal pieces and missing springs from the clutch disc.
Old Oct 25, 2010 | 10:35 AM
ruffrhyder's Avatar
A broken clutch disc spring prevented my car from going into 1st or reverse while the car was one. With the car off, I was able to get the car into gear.
I had the same thing happen to me.
Old Oct 25, 2010 | 11:26 AM
ruffrhyder's Avatar
It could also be bad motor mounts or shift linkage bushings. The fact that other gears do not give you problems leads me to believe the master or slave cylinder are not the problem.
Old Oct 25, 2010 | 01:40 PM
bettsbanger's Avatar
My two cents would be check your master cylinder. This has happened to me on my GSR and my RSX-S a week after I purchased it. On my RSX I drove on it always noticing my clutch fluid slowly but surely dissapearing. Then the day i decided to bleed the line my buddy engaged the clutch to fix the air pockets and thats when i saw fluid squirting from my master cylinder. I didn't notice it for a while, but if your loosing fluid, i'd change out your CMC and CSC if i were you. Don't jump to the conclusion i did thinking I need a clutch, diagnose before performing work.
Old Oct 25, 2010 | 03:41 PM
mgs1098's Avatar
A spring on the clutch disc came out. Happened to me recently.
Alan
Old Oct 25, 2010 | 04:06 PM
EHondaJDM's Avatar
Bleed your clutchline and make sure the clutch master isn't leaking, if that don't fix it than its the pressure plate fingers as said earlier.
When was the clutch installed?
Old Oct 26, 2010 | 03:19 AM
I bleed the line numerous times with no air bubbles when I put in a new slave cylinder and no leaks anywhere. Have no idea when clutch was installed by previous owner. For it to go in gears smoothe I have to be a low rpms or rev it up alittle.
Old Oct 26, 2010 | 03:24 AM
Robinjo's Avatar
Same thing here. Around the same mileage. Just driving around and went to shift, nothing. It turned out to be one of the helper springs had busted.
Old Oct 26, 2010 | 05:55 AM
EHondaJDM's Avatar
Yea its def one of the springs on your clutch. If you've ever driven a car with unsprung clutch its more difficult to get into gear jus like that
Old Oct 26, 2010 | 06:11 AM
EHondaJDM's Avatar
Yea its def one of the springs on your clutch. If you've ever driven a car with unsprung clutch its more difficult to get into gear jus like that.
EDIT:
Jus got back from my friends.
His full face Exedy F1 clutch disc stopped grabbin on the ways to the track on friday.
Long story short we took it apart and his whole friction pad that contacts the flywheel is torn off.
Any ideas what happened guys im stumped.
It looks as if the pad just crumbled and the other side is still brand new.
Old Oct 26, 2010 | 08:53 AM
ruffrhyder's Avatar
EDIT:
Contaminated clutch disc, or poor flywheell surface when the clutch was installed, or improper break in procedure
Old Oct 26, 2010 | 02:01 PM
Good thing I just bought a DD integra, looks like I'm gonna havta tear this one apart Thanx tho guys
Old Oct 28, 2010 | 04:20 PM
EHondaJDM's Avatar
Yea I never seen nothing like it, it was a brand new flywheel n **** we're thinkin defect but no way to prove it
99hondadx
Feb 10, 2017 05:35 AM
turbinedteg7
Jul 13, 2011 08:30 AM
jdm_phunk
Feb 27, 2011 05:17 PM
integranator
Jun 22, 2008 04:04 PM
fred92htch
Aug 23, 2004 01:54 PM
