Valve cover breather nipple to AN fitting?
Old Oct 20, 2010 | 10:12 PM
Charlie Moua's Avatar
Default Valve cover breather nipple to AN fitting?
Has anyone remove the stock breather valve and replaced it with a male fitting?
If so, what size fitting would work best? -6an or -8an?
I'm planning on running two 12"an fittings to catch can but figured while I was putting fittings on I might was well do something with the stock breather nipple rather than just capping it off.
TIA - Charlie Moua
Old Oct 21, 2010 | 09:58 AM
Default Re: Valve cover breather nipple to AN fitting?
Old Oct 21, 2010 | 10:00 AM
thegatekeeper14's Avatar
charli theres a few ways to do it also
Old Oct 21, 2010 | 10:32 AM
champLSinteg's Avatar
Running 2 -12an lines off the valve cover is plenty. What I do is remove the nipple completely then drill and tap the hole for a 1/8npt plug. Looks much cleaner that way.
Or you could take out the nipple, drill a larger hole and weld a -8an bung on it instead.
Old Oct 21, 2010 | 06:07 PM
pictures?
thanks guys
Old Oct 21, 2010 | 06:59 PM
paulzy's Avatar
I pulled out my nipple and welded it shut
Old Oct 21, 2010 | 07:41 PM
yeah that's what i'm probably going to end up doing....
Old Oct 24, 2010 | 11:12 AM
rs250nut's Avatar
Pulled the o.e piece of tube out then drilled and tapped a m10x1.5mm thread to accept an adapter to go to -6.
Old Oct 25, 2010 | 06:01 PM
NotAJDMFanBoy's Avatar
just plug it. a -6 will just make it look more cluttered.
Old Oct 25, 2010 | 06:19 PM
Thanks guys pictures will be up soon... lol
Old Nov 11, 2010 | 12:15 PM
all done
Old Nov 11, 2010 | 04:59 PM
c5R's Avatar
c5R
this was my solution
Old Nov 11, 2010 | 05:41 PM
damn, that's one good looking catch can
Old Nov 12, 2010 | 11:31 AM
MR.johnson's Avatar
what do the baffles look like inside? i would think you would get alot of oil in your catch can. when you run them in the front you want them behind the baffles.
Old Nov 12, 2010 | 12:40 PM
I.C.C.'s Avatar
I did mine the same way with two -10's on the front, and welded the breather hole shut...
Old Nov 12, 2010 | 01:10 PM
c5R's Avatar
c5R
i have a small baffle in front of the fittings in the valve cover the catch can also is baffled with a -10 drain to the block so oil in the can doesn't bother me any ways.
This is how it looks now after i powder coated it all
Old Nov 12, 2010 | 01:38 PM
boostedcivicsir's Avatar
Mr. Badwrench
if you really want to put an an nipple where the stock nipple is, grab it with a pair of pliers. twist the hell out of it. it will come out.
it is close enough to a 1/8npt hole you can tap w/o drilling.
scspeed
Mar 6, 2008 12:23 PM
scspeed
Mar 6, 2008 04:02 AM
Sprockets
Nov 25, 2006 03:47 PM
d16dcoe45
14
Aug 6, 2006 03:12 PM
turboteg2nv
Nov 28, 2004 08:24 AM
