OBD1 help?!
I'm pretty new to this whole OBD thing but I wanna know where i can find a OBD1 computer and ecu. and i also wanna know if i can just get a OBD1 off a different car and it still work?...help plezzzz
ummm easiest way to run that motor is obd0, being that nothing came stock obd1 with a dohc non vtec d16 motor in the states. how was your car converted to obd1? if it was just a jumper harness, simply disconnect the harness, plug in the ecu and you're good to go. alot of people use the dizzy and ecu from 88-89 integras (don't use one from 86-87, forgot why but i think it's something to do with them being low compression). however if the body harness was chopped and soldered then you'll need to replace the body harness at best or cut off the obd1 plugs and resolder the obd-0 ones on
DOHClessEF-9
12
Apr 21, 2005 06:07 PM
KevronsEG
12
Nov 18, 2002 07:57 PM
