is it true that CM makes a cable tranny type clutch for the b16??
Old Sep 20, 2002 | 09:06 AM
Shea-bird's Avatar
New User
Default is it true that CM makes a cable tranny type clutch for the b16??
everyone says to order a clutch kit for a b18 from a '90-'91 teg, but then someone told me that there is a kit for the cable trannies. I called CM and the guy who answered said they did, but he was just replying with a yes or uh huh to every question I shot at him...so I don't know what to think.
[Modified by Shea-bird, 6:36 PM 9/20/2002]
Old Sep 20, 2002 | 10:07 AM
EP3_05's Avatar
Default Re: is it true that CM makes a cable tranny type clutch for the b16?? (Shea-bird)
I just used the b18 clutch for the 90-91 integra. It works fine.
Old Sep 20, 2002 | 10:15 AM
SuperCivic's Avatar
the b18 teg tranny IS a cable tranny.
Old Sep 20, 2002 | 12:14 PM
Shea-bird's Avatar
New User
Default Re: is it true that CM makes a cable tranny type clutch for the b16?? (SuperCivic)
I know this, but it is not specifically designed for the high revving b16. so I was wondering if there was an actual b16 clutch kit...
Old Sep 20, 2002 | 12:26 PM
Malgerus's Avatar
The clutch doesn't care about how high you rev It cares about torque and power... there probably is a clutch kit, but not in the US I would think.
Old Sep 20, 2002 | 12:53 PM
dustin's Avatar
Same thing.
Old Sep 20, 2002 | 03:35 PM
rice4life's Avatar
Default Re: is it true that CM makes a cable tranny type clutch for the b16?? (dustin)
the Y1 tranny uses 90-91 teg clutch and YS1 tranny uses 92-93 teg clutch.
Old Sep 20, 2002 | 08:34 PM
Shea-bird's Avatar
New User
Default Re: is it true that CM makes a cable tranny type clutch for the b16?? (rice4life)
see the thing is I don't know which I have...the serial # is nowhere to be found...I guess I'll just have to open it and see
Old Sep 20, 2002 | 10:37 PM
incubus's Avatar
y don't u just look at the series engine ur b16 is. if it is a 1 million series engine you can summise that u have a y1(j1) tranny if it is a 3million than a y1. more than likely the tranny and engine have been mated together their whole life. that actually brings up a question I have. Can u use a hydro tranny clutch say a civic si or ITR clutch on a cable tranny like the y1's? And if u can't y not??? one thing i REALLY lack knowledge in is trannys so i just don't understand.
Old Sep 20, 2002 | 11:02 PM
dustin's Avatar
Default Re: is it true that CM makes a cable tranny type clutch for the b16?? (incubus)
92+ clutches use a larger input shaft than 90-91. You can technically fit a 92 clutch on a 90-91 transmission, but one decent launch and it will strip right out.
Cable/Hydro is of no consequence.
Dustin
ciro
Transmission & Drivetrain
Oct 15, 2012 08:10 AM
95dc2teg
Jul 8, 2008 11:36 AM
CRX-project-car
May 16, 2007 09:21 AM
jpangeles
Sep 22, 2006 01:47 AM
S13 slide
Aug 20, 2003 11:43 AM
