Replacing cap and rotor
Old Oct 20, 2010 | 04:00 PM
eazy64's Avatar
Default Replacing cap and rotor
okay my rotors all lose and i wanna replace it but i wanna know if u have to get it timed afterwards??? thanks
Old Oct 20, 2010 | 04:11 PM
Fo-Do Fanatic's Avatar
Default Re: Replacing cap and rotor
No. There's a bolt that goes through the rotor and screws into the distributor itself, hence it setting it in the right position. Make sure you use an allen key or a torx may work as well.
Old Oct 20, 2010 | 04:14 PM
eazy64's Avatar
oright thanks brooo.
Old Oct 20, 2010 | 06:06 PM
BiG ChOr!Zo's Avatar
no
Old Oct 20, 2010 | 07:18 PM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
Sometimes the shaft and opening for the screw are facing an impossible to access way. Blip the starter or manually rotate the motor to make it easier.
Old Oct 20, 2010 | 08:05 PM
eazy64's Avatar
okay i was trying to reach the screw and that **** was hard to get to. okay so i have to like crank the engine until it turns the rotor.
Old Oct 20, 2010 | 09:24 PM
EL Vap133's Avatar
If the screw is hard to take off don't strip it. Use an impact driver.
Old Oct 21, 2010 | 03:13 AM
Grey_Matter's Avatar
really???
why do you attempt to give advice if you dont know the answer to this????....
stop posting please
Old Oct 21, 2010 | 03:18 AM
jcolando's Avatar
Be sure to get the screw tight when your finished, I had one come loose one time really messes up the distributor.
Old Oct 21, 2010 | 04:45 AM
Originally Posted by Grey_Matter
really???
stop posting please
he is the op of this thread idiot
belairbrian
10
Mar 1, 2013 06:14 PM
97SS
May 12, 2009 10:07 PM
Sir Kyle
May 10, 2008 06:30 PM
doggunracing
Nov 6, 2003 09:24 PM
blackls
Jul 5, 2001 07:31 PM
