JIC Magic FLT-1US Coilovers for EF/EG/EK/DC/CRX
What: JIC Magic FLT-1US coilovers
Where: Leesburg, VA
Price: $500obo picked up (will ship at buyers expense)
contact: PM or joenationwide@yahoo.com
Have some used JIC Magic coilovers FLT-1US I believe. They are the non adjustable ones. (Height and preload are adjustable, but not compression/rebound). I am running them on an EK Civic, however you can run them on EF, EG, and EK Civics, DC Integra, or any 88-91 CRX because I'll give you the front lower shock wishbone mounts if you need them (originally for a CRX). And if you have an EK, I'll give you the spacers to fit the rear LCAs.
The threads on the shock bodies have some surface rust, but work fine. I put some anti seize on them so I didn't have any problems adjusting them. I just installed a set of adjustable AST 4100 suspension so I no longer need these.
Comes with everything shown in pics:
Front JIC coilovers with Skunk2 custom spring rates
Rear JIC coilovers with original JIC springs
Front shock lower wishbone mounts
Rear LCA spacers
All bushings and washers for stock upper shock mounts
Where: Leesburg, VA
Rear LCA spacers
Fo-Do Fanatic
Jan 20, 2010 10:17 AM
