Proper throttle body cable tension -93 honda civic VX
Old Oct 20, 2010 | 12:13 PM
1sthonda's Avatar
Default Proper throttle body cable tension -93 honda civic VX
How do I find out the proper cable tension for my TB? My car has 320k miles on it, so I'm under the impression that the cable has stretched and things have worn down. Right now there is no tension on the throttle body via the cable. The cable has a little bit if slack before it engages the TB so the TB is completely closed. Shouldn't it be cracked ever so slightly?
Thanks for your input.
Old Oct 20, 2010 | 12:53 PM
94EG8's Avatar
Seagull Management
Default Re: Proper throttle body cable tension -93 honda civic VX
There should be a small amount of slack in the cable, if theres not it can cause idle issues.
Old Oct 20, 2010 | 06:26 PM
-__-'s Avatar
320,000!? wow congratulations lol. and yes there should be some slack. if u adjust it, make sure it does not hold the throttle body open.
BryanM.
Jan 10, 2022 04:16 PM
dustywebber
Jul 10, 2004 09:04 AM
