91 ls non-vtec b18a1. wut would be best to upgrade next.
Old Oct 20, 2010 | 10:31 AM
raguilar7's Avatar
Default 91 ls non-vtec b18a1. wut would be best to upgrade next.
Just put a skunk2 intake manifold, skunk2 throttle body, throttle body spacer, and no name headers. Also installed a test pipe and skunk2 exhaust from the test pipe back. Just needing some ideas on wut to do next. Should i change out to after market fuel rail, injectors, fuel pump, fuel regulator, fuel filter. Or do modifications to the engine internals and if so wut should i modify first?
Old Oct 20, 2010 | 10:35 AM
brettj20's Avatar
Default Re: 91 ls non-vtec b18a1. wut would be best to upgrade next.
bigger cams
Old Oct 20, 2010 | 10:36 AM
dntnedvtec's Avatar
Crower cams, Cam gears and Valve springs/retainers. After that, get a tune and you will be set. Unless you want to go all out and grab a set of high comp pistons. Don't worry about fuel delivery. The stock systems are good up to 400whp(not the injectors)
What is your goal for power??
Old Oct 20, 2010 | 11:05 AM
raguilar7's Avatar
My goal is for more horsepower. Wut crower cams should i go with exhaust, or intake or turbo? I as looking at the site and i don't know wut to go with? Same for the cam gears, valve springs/retainers. And ya i wanna go all out so wut do u prefer for high comp pistons. Its a 91 ls integra with a b18a1.
Old Oct 20, 2010 | 11:42 AM
Mattb16teg's Avatar
Community Builder
Community Influencer
Honestly if your goal is for more power, throw a turbo kit on the ls, a Vtec head on the Ls or swap out the motor.
Old Oct 21, 2010 | 04:16 AM
dntnedvtec's Avatar
Boost is the best way with an LS. A set of cams will also do you good as well. I would say go a 403 cam. I read somwhere on here, the 403 cam nets faster boost response than crowers turbo cam..
Old Oct 21, 2010 | 04:43 AM
na+b18c_hatch's Avatar
took the words out of my mouth. if you want power and still have a nice daily driver, go with a smaller turbo that will make power but also retain your honda's driveability.
.. just my $0.02
Old Oct 21, 2010 | 05:53 AM
Mattb16teg's Avatar
Community Builder
.. just my $0.02
The size of the turbo has nothing to do with reliability though. I'd even want a moderately sized turbo so in normal driving I'm not hitting boost.
Although I've never really thought of a turbo Honda as a good DD choice, just my opinion though.
Old Oct 21, 2010 | 07:11 AM
HondaHatch1's Avatar
he said driveability not reliability.
Old Oct 21, 2010 | 07:30 AM
Mattb16teg's Avatar
Community Builder
LoL Doh! Sure that didn't say reliability this morning?
Old Oct 21, 2010 | 09:10 AM
nokturnal_munkeeboy's Avatar
first build your engine how you want to add your goodies then you need to get it tune for reliable performance
Old Oct 21, 2010 | 10:44 AM
Mattb16teg's Avatar
Community Builder
Ok, I'll put it to you this way, how many fast/quick/high hp/modded, etc LS cars do you see?
Not saying what your doing is wrong but anyone modding a car is wanting go to faster and get more power. Just saying your venturing down a tough road!
Old Oct 21, 2010 | 10:49 AM
positive. I wouldn't have said reliability because I know that installing a turbo kit on a 91 integra is probably not going to be all THAT reliable lol. I like the term "driveability" when referring to a balanced combination of power and practicality. In other words, has sufficient power and can also be used as a [somewhat] comfortable and fuel efficient daily driver.
Old Oct 21, 2010 | 11:04 AM
Mattb16teg's Avatar
Community Builder
LoL, I know, I was joking, I even quoted you so I saw it, just a bit sleepy!
boosted hybrid
Aug 25, 2007 08:22 AM
Gatweb
23
Mar 9, 2005 06:39 PM
Chris_Bye
Jul 3, 2004 07:46 AM
12secEGhatch
Nov 24, 2003 02:25 PM
