Honda CR-V & Element 2WD & 4WD Element & CR-V
ENGINE TURNS OVER BUT NOT FIRING?
Old Oct 20, 2010 | 08:30 AM
NOVALEE66's Avatar
Default ENGINE TURNS OVER BUT NOT FIRING?
I HAVE A 2000 HONDA CRV, 138,000 mi. It's been running just fine, then all of a sudden, went to start it up one morining and it wouldn't start. Engine turns over but not firing. So far, I checked spark plugs, distrubutor and wires, fuses. One mechanic put in some kind of relay sensor? Something like that...still to no avail. All have said that battery is good if it turns over...is this necessarily the case? One mechanic said it could be ECU but others say it's very rare for them to go bad. What else can I check that would bring on this problem.....all of a sudden with no warning signs? I've read to check battery, connections, fuel and/or faulty fuel guage, fuel injection, fuel pump, ignition coil/coil (one in the same?).....please help. Thanks!
Old Oct 20, 2010 | 11:46 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: ENGINE TURNS OVER BUT NOT FIRING?
You need to find out if its not getting fuel or spark. Most likely it'll be spark but here are some troubleshooting links for the main relay and ignition system
http://techauto.awardspace.com/mainrelay.html
http://techauto.awardspace.com/ignition.html
Old Nov 8, 2010 | 07:15 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Bump... seems my CRV is starting to do this when its cold. Anyone experience this?
Old Nov 10, 2010 | 11:23 PM
lee34's Avatar
I am having the same problem.If there is any solution for it,please do tel me.
vdrive502
Apr 6, 2018 02:37 PM
Josh Jennings
Oct 30, 2016 03:35 PM
Derekhatch92
11
Feb 4, 2010 10:06 PM
Red1ine
Apr 2, 2008 10:09 AM
boostng r
Sep 11, 2004 03:16 AM
