Eibach Alignment Kit No More tire wear..
Old Oct 20, 2010 | 07:53 AM
k20user's Avatar
Default Eibach Alignment Kit No More tire wear..
http://hondamarketplace.com/showthread.php?p=43819000
CALL: 714 622 96FOUR-EIGHT-
$100
This product fits the following:
Footnotes: Adjustable Ball Joint. Front - Camber +1.5 To +3.0 Degrees Of Adjustment.
Make Model Year Engine Type Application Note Detail Color
Acura Integra 1994 - 2001 (N/A) 2 & 4-door Incl. GS GS-R RS LS & Type R Front +1.5 / +3. degrees of adjustment. (N/A)
Acura Legend 1990 - 1993 (N/A) 2 & 4-door Incl. GS-R Front +1.5 / +3. degrees of adjustment. (N/A)
Acura Legend 1991 - 1995 (N/A) 2 & 4-door Front +1.5 / +3. degrees of adjustment. (N/A)
Acura RL 1995 - 1998 (N/A) 3.5 Front +1.5 / +3. degrees of adjustment. (N/A)
Acura TL 2009 - 2010 3.5L V6 Exc. Type-S Front +/-3.00 degrees of adjustment. (N/A)
Acura TSX 2009 - 2010 2.4L I4 CU2 Exc. Turbo Diesel Front +1.5 / +3.0 degrees of adjustment. (N/A)
Acura TSX 2009 - 2010 3.5L V6 CU2 Front +1.5 / +3.0 degrees of adjustment. (N/A)
Honda Accord 2006 - 2007 3.0L V6 Coupe Front +1.5 / +3. degrees of adjustment. (N/A)
Honda Accord 2006 - 2007 3.0L V6 Sedan Front +1.5 / +3. degrees of adjustment. (N/A)
Honda Accord 2008 - 2010 2.4L I4 2 & 4-door Front +1.5 / +3. degrees of adjustment. (N/A)
Honda Accord 2008 - 2010 3.5L V6 2 door Front +1.5 / +3. degrees of adjustment. (N/A)
Honda Accord 2008 - 2010 3.5L V6 4-door Exc. Hybrid Front +1.5 / +3.0 degrees of adjustment. (N/A)
Honda Civic 1992 - 1995 (N/A) 2 & 4 door Front +1.5 / +3. degrees of adjustment. (N/A)
Honda Civic 1996 - 2000 (N/A) 2 & 4-door Incl. EX DX HX LX & Hatchback Models Front +1.5 / +3. degrees of adjustment. (N/A)
Honda Del Sol 1993 - 1997 (N/A) (N/A) Front +1.5 / +3. degrees of adjustment. (N/A)
Will accept pickup.
Old Oct 20, 2010 | 04:17 PM
ChrisRogers's Avatar
Default Re: Eibach Alignment Kit No More tire wear..
Bump for you
Old Oct 20, 2010 | 09:12 PM
k20user's Avatar
thanks!
Old Oct 22, 2010 | 12:00 PM
Sir Ash's Avatar
does that replace the stock ball joint on the stock upper control arm?
Old Oct 22, 2010 | 01:39 PM
k20user's Avatar
yup! so you can adjust your camber.
Old Oct 25, 2010 | 06:13 PM
k20user's Avatar
ttt
Old Nov 2, 2010 | 10:47 AM
k20user's Avatar
ttt
Old Nov 10, 2010 | 09:30 PM
k20user's Avatar
Old Nov 11, 2010 | 07:05 PM
k20user's Avatar
ttt
Old Nov 19, 2010 | 08:29 PM
k20user's Avatar
ttt
k20user
Dec 22, 2011 09:51 AM
Chief Brody
Wheels
Jul 27, 2010 05:03 PM
SiMateoAko
Mar 30, 2006 07:13 AM
es_squared
Nov 5, 2004 05:20 AM
AssPenny
Apr 16, 2002 10:19 AM
