Replacing radiator support need help
Old Oct 19, 2010 | 07:57 PM
Gregg-Petty's Avatar
Default Replacing radiator support need help
Wrecked my 93 civic hatch need to replace my radiator support but don't have a clue where to start can anyone help?
Old Oct 19, 2010 | 08:31 PM
jdmadam's Avatar
Default Re: Replacing radiator support need help
If you dont know what you are doing do not attempt it.
You would have to cut/drill your damaged support out and then measure and weld the new one in. Measuring has to be spot on or you will have a hood that doesnt shut and fenders,bumpers and headlights that wont line up correctly. Do you even know how to weld?
Old Oct 20, 2010 | 09:56 PM
jere's Avatar
http://cgi.ebay.com/ebaymotors/92-93...Q5fAccessories
They arent hard to find if you need one. You will need spot weld bits and a welder or someone that can weld it for you.
If you are worried about the alignment or don't weld you might find a collision shop that does this stuff all the time. If you have AAA you could take everything apart you can (drilling spot welds isn't that hard with the right bit check youtube) and so on then call a flatbed bring the new support with the car and have them do the rest. It will be cheaper that way. Just set it up with the shop before hand. Some shops won't do it.
Draggin99Si
Northern California (Sales)
Aug 28, 2007 08:42 PM
potential
May 20, 2006 08:26 PM
November
Welding / Fabrication
May 16, 2006 06:54 PM
sickazzcivic69
Oct 6, 2005 04:50 PM
