Replaced timing belt: dead
Old Oct 19, 2010 | 04:54 PM
Jaynik's Avatar
Default Replaced timing belt: dead
I have a 1996 hatchback here that had the timing belt skip a tooth which made it not run.
I replaced the belt and it ran great for about 10 minutes of vigorous driving and then suddenly died. It doesn't appear to have spark, that is to say a timing light won't blink while hooked up to it.
I verified that the timing is still lined up and even replaced the crankshaft position sensor for good measure.... Still dead.
What could I have screwed up? I'm at a loss.
Old Oct 19, 2010 | 05:50 PM
fv8s's Avatar
Default Re: Replaced timing belt: dead
pictures? you most likely bent valves, or you did not time the motor properly ( #1 piston at TDC and your cams "up" mark up along with the two lines)
Old Oct 19, 2010 | 05:57 PM
Jaynik's Avatar
Cam is up, the two hash marks on either side of the cam are lined up with the head, and the hash mark on the crank pulley is lined up with the sight arrows on the side of the timing belt cover. I don't have pics ATM but I have double checked...
Can bent valves cause no spark?
Old Oct 19, 2010 | 05:59 PM
fv8s's Avatar
no. are you positive you have no spark? pull out the wires/plugs and crank it. if you see it arc then you obviously have spark
Old Oct 19, 2010 | 06:00 PM
Former User's Avatar
Any CEL codes?
Does the fuel pump prime? If so, test the coil and have an auto parts store test the ICM. Old plugs, wires, cap, or rotor can cause the coil to blow.
Old Oct 19, 2010 | 06:10 PM
Jaynik's Avatar
I'll check for the spark plug arc when I get home, there are no cel codes and the fuel pump def primes and the main relay makes all the proper clicks
Old Oct 19, 2010 | 06:12 PM
fv8s's Avatar
check your ignition coil like Ron stated and re-check your timing. was this your first time doing a timing belt?
Old Oct 19, 2010 | 06:19 PM
Jaynik's Avatar
I will check the ignition coil as well pending the verification of lack of spark. This was my 7th or 8th Honda timing belt replacement.
Old Oct 19, 2010 | 06:21 PM
fv8s's Avatar
o your a pro by now
Old Oct 19, 2010 | 06:26 PM
Jaynik's Avatar
That's whats so frustrating!
Old Oct 19, 2010 | 06:29 PM
fv8s's Avatar
is the distributor back in the correct way and tightened down? you may have un-plugged something and forgot to plug it back in. i did a headgasket before and was cranking it for five minutes without it starting. it ended up being an unplugged dizzy.
Old Oct 19, 2010 | 06:34 PM
Jaynik's Avatar
Dizzy is plugged in i even marked it and ctook it off and put it back to make sure it was on correctly
Old Oct 19, 2010 | 06:35 PM
fv8s's Avatar
darn. figured i'd ask. i say take the head off and check the valves. did you hear any odd ticking or BANG! lol
Old Oct 19, 2010 | 06:38 PM
Jaynik's Avatar
Nope
Old Oct 19, 2010 | 06:39 PM
fv8s's Avatar
take some pictures for us. its a shot in the dark without seeing what you have done
Old Oct 19, 2010 | 06:43 PM
Jaynik's Avatar
Roger
Old Oct 19, 2010 | 06:46 PM
fv8s's Avatar
thanks mang
Old Oct 19, 2010 | 09:49 PM
Jaynik's Avatar
Confirmed: No Spark. More to come.
Old Oct 19, 2010 | 10:21 PM
Jaynik's Avatar
Pulled the ICM and the resistance was NOT on point AND it had visible burn markings on it. Will get a new one tomorrow. Is it possible this is just an unhappy coincidence or is there a possible cause and effect between something I did wrong with the timing belt and the ignition control module?
Old Oct 20, 2010 | 01:03 PM
Jaynik's Avatar
Correction: The ignition COIL tested bad not the icm
Old Oct 20, 2010 | 06:19 PM
-__-'s Avatar
nice. i like when people find out their problem haha. and it could totally be a coincidence. My friend blew his head gasket and we put the motor back together. It wouldn't start. Turns out his Distributor was bad too. Now it runs like a champ. 180,000 miles
alex14
12
Sep 29, 2010 01:01 AM
haters I got
Mar 24, 2010 11:48 AM
EKwreckRLS
44
Mar 18, 2010 06:48 PM
NewRacer
May 13, 2003 07:58 PM
Chris_
Nov 19, 2002 06:15 PM
