meth injection on a na built gsr?
Old Oct 19, 2010 | 12:31 PM
Slowp0ke's Avatar
Default meth injection on a na built gsr?
whould running meth injection on a built high compression gsr motor a good alternitive to not running race gas?
also whould it still be concidered N/A with meth?
please clear this up thank you guy!
Old Oct 21, 2010 | 04:33 PM
Slowp0ke's Avatar
Default Re: meth injection on a na built gsr?
?? anyone?
Old Oct 21, 2010 | 05:01 PM
turbo82's Avatar
Yes you can run it so you don't have to run race gas. If your gonna be running at events in an all motor class, NO it can not be used. If the comp in your sig is what your talking about your border line for pump gas. Some people say 12.5.1 is the limit for pump some say 13.0.1.
Old Oct 22, 2010 | 05:08 AM
AcKuRRa-tEcH's Avatar
WORKS GOOD IN HIGH COMPRESSION MOTORS IMO
Old Oct 22, 2010 | 07:51 AM
lunatics209's Avatar
Yes meth is fine but you'll have to run brackets. All heads up street all motor classes prohibite methanol. Unless you're looking to run Pro AM. I would look into E85. Poorman's race gas...
Old Oct 22, 2010 | 08:22 AM
Slowp0ke's Avatar
we have no e85 around our area.... what about 93 pump with tolulene? (however you spell it) will that work and yield me the octane level i need?
and if i just run straight 93 pump what whould YOU tune with to get the most power out of her?
Old Oct 22, 2010 | 12:20 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
I hope you have some big cams too to help make everything work well together.
Old Oct 22, 2010 | 12:45 PM
turbo82's Avatar
What does cam size have to do with anything? Meth injection work well with any setup.
Old Oct 23, 2010 | 12:45 PM
Loved
Community Favorite
cam size has nothing to do with building a high comp na motor?
Old Oct 23, 2010 | 02:25 PM
1.5Slowmatic's Avatar
tolulene will eat away at your fuel lines. yes you can do it but its not smart. a good tuner will take care of you and be able to make you run on pump
nope
Old Oct 23, 2010 | 02:35 PM
turbo82's Avatar
Cam size has nothing to do with compression. Now the performance of a high comp motor....yes. Plus the OP ask about Meth injection as an alternitive to race gas, so cams, compression, boost, or N/A has nothing to do with his question.
Old Oct 23, 2010 | 03:01 PM
turbociv910's Avatar
i know this is the NA forum, but i run toluene and e98 2:3 mix in my boosted civic. seems to work well and LOVES timing.
Old Oct 23, 2010 | 04:40 PM
Loved
Community Favorite
Originally Posted by 1.5Slowmatic
nope
so cam size as in duration has nothing to do with compression, please explain.
really. have you ever heard of dynamic or effective compression ratio. if not read into it. it says that your true cr ratio doesn't even start till the last intake valve is closed and the cylinder can actually seal. the more duration you have the more of your static cr you can "bleed off" (hate to use that term) hence why I asked if he had big cams to make everything work well together.
if you think other wise id love to hear your argument or maybe Im just not hearing what your getting at here.
Old Oct 23, 2010 | 05:30 PM
turbo82's Avatar
Ok maybe I think out of the box to much. So with what you just said, Valves closed and cylinder sealed. Wouldn't that be just like not having a cam in the head? Or am I seeing something wrong here?
Old Oct 23, 2010 | 10:37 PM
Loved
Community Favorite
the valves don't close until after the piston travels up a little bit. this depends on the duration that the cam has. this is why cam choice has alot to do with what cr you can run on pump gas.
Old Oct 24, 2010 | 05:47 AM
88Hatchy's Avatar
It's all about when the valves open and close, chief.
Slowp0ke
25
Sep 30, 2010 04:24 AM
jdmb16ef8
Aug 19, 2007 03:10 PM
flatty
16
Nov 25, 2005 06:49 AM
ErikDaGenErik
12
Apr 9, 2005 09:33 AM
Pinhead
Jan 31, 2002 09:44 AM
