FS: One very AWESOME B Series Swap. =( Omaha Nebraska.
As Title States. 5500 OBO
Call/Text (402) 201-7009. Names Chris.
Never thought i would be in a Position to do this but i have to Semi Part out the SiR. Unexpected Circumstances arose&i am Forced to let go for a little Cash in my Favor. Don't worry my EF8 will NEVER be up FS. She is actually go'n to be put in Storage for a Few Years. Hopefully after Deployment i'll be able to do her Justice like she Deserves.
New Engine Set up has never been Ran yet.
Previous PMTR Build w/ Skunk2 IM 70MM TB 310cc RC Injectors Skunk2 Stage 2 Tuner Camshafts+Tri-Y Rage Header made 206WHP.
Just a Rough Run Down on Prices for the Haters:
TODA Vtec Killer Camshafts - 2000
TWM Individual Throttle Bodies - 1500
Custom Bisimoto V2 Header - 900
AEM EMS Stand Alone - 1000
Clean Low Mileage VIN'd ITR Transmission - 1000
Now on to the Gooodies!!!
*Head Package (PR3)
~New OEM Honda Items:
-Camshaft Gear Bolts
-Camshaft Seals
-Valve Cover Gasket&Plug Seals
-Metal Exhaust Gasket
-Air Temperature Sensor
`TODA 295 Vtec Killer Camshafts (Still have the Boxes)
`Limited Edition Full-Race Camshaft Gears (GOLD)
`Omni Power Dual Valve Springs
`Omni Power Titanium Retainers
`Supertech Bronze Valve Guides
`Omni Power High Compression Flat Valves
`Mugen Metal High Compression Head Gasket
`TWM 52MM Individual Throttle Bodies
`4 Carbon Fiber Velocity Stacks
`TWM Lock&Play Fuel Rail w/ 550cc Injectors
`TWM Fuel Pressure Regulator
`Liquid Filled FPR Gauge (Forgot Name)
`Hondata Intake Manifold Gasket
`Custom Bisimoto V2 Header Ceramic Coat'd
`Rare Polished STR Cam Seal
`PasswordJDM CF Spark Plug Cover
`Custom One Off Avid Racing AN -16 Coolant Necks
`ARP Stainless Steel Exhaust Stud Kit (12 Point)
*Block Package (B18C1)
~New Honda Items:
-Water Pump (P72)
-Honda Oil Pump (P72)
-Timing Belt (P72)
-Oil Pan Gasket
`Golden Eagle headstud
`.25MM OS JDM B16A P30 11.6:1 C/R
`ARP Rod Bolts
`ACL Main&Rod Bearings
`Full-Race Breather Box Plug
*Drive-train
~New Items from Honda:
-2 Starter Bolts
-Flywheel Bolts
-Throw Out Bearing
`High Compression Beast Starter
`Exedy Hyper Single Carbon Clutch
`USDM Type R Transmission w/ VIN (Roughly 20K)
`Clutch Slave Cylinder
`Original Uncut Shifter Fork Boot
`Gator Stage 1 Axles w/ Intermediate Shaft
*Engine Management/Electronics/Ignition
`OBD1 AEM EMS w/ Software Disc&USB Cables
`Spoon Sports High Tension Wires
`NGK Laser Platinum Spark Plugs
`OBD1 GSR Distributor
`OBD1 Alternator w/ AEM Pulley
`Brand New Bosch O2 Sensor
`AEM Uego Wideband w/ Digital Gauge
Will get more Pictures if Request'd.
*Head Package (PR3)
-Camshaft Seals
~New Honda Items:
-Water Pump (P72)
-Timing Belt (P72)
-Oil Pan Gasket
`ARP Rod Bolts
*Drive-train
-2 Starter Bolts
-Flywheel Bolts
-Throw Out Bearing
Maybe consider Part Out if i get enough Spoken for Items w/ Non-Refundable Deposits.
TODA Camshafts w/New Full-Race Cam Gears (New Cam Bolts&Seals) -1400 OBO
Custom Bisimoto V2 Header Cermaic Coat'd 2.75" Outlet - 1100 OBO
New TWM ITB's 52MM 550cc Injectors CF Velocity Stacks - 1500 OBO
ITR Transmission New Honda Throw out Bearing Slave Cylinder etc - 1100 OBO
Exedy Hyper Single Carbon Clutch w/ Brand New Honda Bolts - 800 OBO
PMTR Long Block minus Header Camshafts ITB's - 1400 OBO
AEM EMS Stand Alone ECU System - 800 OBO
PM or Reply on here if you are interested in anything else.
Thanks, not sure yet. Commander gave me an option to Reclass so i can Enjoy my Job instead of the one i have now. So we'll see what's in the works. Storage Unit has been Purchase (12x35), EF8 will be in there sometime this week =[
b20vtecGSR
15
Feb 25, 2017 09:01 AM
