oil on spark plugs
Old Oct 19, 2010 | 05:44 AM
F22 Accord's Avatar
Icon2 oil on spark plugs
Does anybody know why oil keeps getting on my spark plugs hole...
It’s a seal?? Or the Valve cover needs to be tighter??
Will this affect my car??
Thanks
Old Oct 19, 2010 | 05:55 AM
H22CB9's Avatar
Default Re: oil on spark plugs
Should be your Tube seals. Replace those and should fix it.
Old Oct 19, 2010 | 05:58 AM
F22 Accord's Avatar
thnks
H22CB9
Old Oct 19, 2010 | 06:46 AM
H22CB9's Avatar
Originally Posted by F22 Accord
thnks
H22CB9
No problem
Old Oct 19, 2010 | 09:12 AM
nus_dogg's Avatar
F22B1 or F22B2? There's the bottom spark plug o-ring that you'll need to replace if its a B2 motor. You'll need to remove the rocker arm assembly then replace the bottom spark plug o-rings and thats it for the B2.
B1 I believe only has the upper o-rings underneath the valve cover.
Old Oct 19, 2010 | 09:45 AM
chikin pickle's Avatar
Both have seals on the valve cover. B2 has the rocker assembly seals though.
Old Oct 19, 2010 | 10:05 AM
F22 Accord's Avatar
it a f22b1
Old Oct 19, 2010 | 01:05 PM
HondaPartsHero's Avatar
Technical Hero
I would try the upper seals first before attempting the bottom seals as they are a bit more difficult to replace unless needed but if you do:
http://www.youtube.com/watch?v=wYU8q...layer_embedded
Old Oct 19, 2010 | 05:37 PM
fujian90's Avatar
Irregularly working spark plugs use up more fuel and money.
Old Oct 19, 2010 | 05:42 PM
CDdubz5's Avatar
i had this issue on my f22b2 and i replaced the valve cover gasket and o rings twice. the second time i cleaned the area where the o-rings sit and put a dab of sealer on and it has been fine ever since. this is a very common problem on the f series
Old Oct 20, 2010 | 04:44 AM
nus_dogg's Avatar
If its a B1, try the upper o-rings first. I've yet to hear anything bad about the bottom o-rings on the B1.
Old Oct 20, 2010 | 09:44 AM
F22 Accord's Avatar
thanks yall...
Old Oct 23, 2010 | 02:59 AM
joe_accord23's Avatar
You Need a new engine!!!!!!, lol jk, its ur seals, the plugs holes on the valve cover, and b2 has lower tube seals. replace top ones first.
Old Oct 23, 2010 | 04:16 PM
quickster's Avatar
it can also be a bad pcv valve.happened to mine about a year ago. just had oil in the middle right onw. thats a $3 fix and easy. pray its not your lower tube seals, those are a bitch.
Old Oct 23, 2010 | 11:05 PM
Thats because the B1 heads don't have lower tube seals.
Old Oct 29, 2010 | 03:19 PM
CDelgado220's Avatar
I agree. I had same issue on my B2 fixed the top ones and valve cover to see if that fixed situation but still has some oil in spark plug well... I haven't done bottom one's yet b/c I don't have needed tools but I will probably take to local mechanic and have them just redo the entire thing alomng with lower ones .. That video above is awesome, informative & entertaining.. wish I had the tools
JDManuel
Feb 2, 2010 05:02 PM
jose310
Jan 12, 2009 01:38 PM
square_1
Jul 21, 2006 11:14 PM
DrewQ1
Nov 9, 2004 04:48 PM
7rrivera7
Dec 21, 2003 03:47 PM
