need vtec ecu
Old Oct 18, 2010 | 07:50 PM
scottypippen147's Avatar
Default need vtec ecu
ok so i put a f23a1 out of a 98 accord into my 90 accord and it is running off of the stock ecu right now. if i wanted a vtec ecu wat ecu's could i use? i found a poa-a01 ecu out of a 94 vtec accord and i know that will work but my friend also told me i could use a h22 ecu. is this true? or would timing and runability be completely different?
Old Oct 18, 2010 | 08:36 PM
nus_dogg's Avatar
Default Re: need vtec ecu
I will not run an H22 ECU because the Air/Fuel mapping is different. It can ruin and damage your motor if run long enough to that point. It's not meant for a Single Cam motor while the H22 ECU is built for the DOHC VTEC motor.
Old Oct 18, 2010 | 08:40 PM
ok so is the poa ecu my best bet then? or if i wanted to step it up i guess i could do a chipped p28 lol
Old Oct 18, 2010 | 08:44 PM
nus_dogg's Avatar
Yes, if you want to be able to dyno and tune your car, go with a P28 chipped ECU with the F23 basemap.
Old Oct 18, 2010 | 10:21 PM
bseriescrxsi's Avatar
i have a 1994 VTEC converted P75 board number is 1720 and the chip is a 232.....if you want to buy it its 160 plus shipping....bought it from ghost accord
accord_turbo
Engine Management and Tuning
May 30, 2013 12:27 AM
g0at357
Dec 25, 2007 06:56 AM
Hondaflight
Jun 10, 2006 01:29 AM
ICEMAN707
Mar 20, 2006 05:42 PM
dominate9
Jun 8, 2003 04:49 PM
