Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Trans OR torque converter? please look.
Old Oct 18, 2010 | 05:24 PM
chronbox's Avatar
Default Trans OR torque converter? please look.
hey all,
well i know about the trans issues with the car( its an 01 1.7 automatic) and it has been slipping occasionally. well it all out died. car moves into every gear but doesn't move at all.
i have read that its the torque converter that fails usually. And from what I've been reading about my car not moving and just revving, this seams to be the issue.
I was just looking on some input on whether you guys think that i need an entire transmission or just the torque converter?
TIA!
Old Oct 18, 2010 | 09:15 PM
em2power's Avatar
Default Re: Trans OR torque converter? please look.
Sounds like a tranny issue, I would check for leaks, if it is the torque converter there will usually be a large amount of leakage, (red liquid) under the car. Check when shifting from neutral to drive and neutral to reverse if it leaks... Tranny rebuild can run upwards of 2000 dollars, so hope its not the whole tranny...
Old Oct 18, 2010 | 10:47 PM
It Wasn't Me's Avatar
The automatics are well-known for premature failure. If your transmission lasted 100k miles, you're very lucky. I doubt it's the torque converter. It's more likely to be an internal component failure and will require an simple overhaul or possible replacement of the transmission.
Checked the ATF level? Is it low? Can you see any leaks?
Does the "D" indicator flash?
Has the MIL (check engine light) come on? If yes, which codes?
Old Oct 19, 2010 | 12:46 AM
DC209's Avatar
sorry to say but its ur tranny same thing happened to a car i just finished on friday u will need to remove the tranny and rebuild these trannys are known for this u will need to replace the clutches and the internal filter comes complete in the kit its a bitch to remove the tranny from the car lol
Old Oct 19, 2010 | 01:09 AM
chansta's Avatar
dont just take these guys words for it and take steps to prevent spending major money... check ur tranny fluid first. if its really dark its most likely your tranny and you're going to need to rebuild it. could also be the torque converter internals... could be loose or slipping making your car not move.
Old Oct 19, 2010 | 04:48 AM
husyk's Avatar
If a rebuild can cost to you $2000, might as well get a another one or swap to manual.
Mugen112
Transmission & Drivetrain
May 18, 2009 08:09 PM
YipMan_Style
Nov 19, 2008 12:00 PM
stevescivic
Apr 12, 2007 03:58 PM
bloobin
Aug 6, 2004 01:04 PM
