B18 Swap cranks doesn't turn over
Old Oct 18, 2010 | 04:16 PM
JorgeD1990's Avatar
Default B18 Swap cranks doesn't turn over
I put a b18a1 into a 94 tege the old block was knocking well i got a hold of another engine the b18a1 which wont turn over now i am getting fuel i know that cause i have a gauge on my fuel filter which reads 45psi and when the car isnt being started it drop well today i sprayed starter fluid into my car causing a fire back fire coming out of my intake but now when i try and start it it cranks for like 2 seconds make a poping noise kinda like a backfire and kinda trys to start and sugestions what could be wrong also i have a d16 dizzy which plugs up i was kinda low on cash
Old Oct 20, 2010 | 04:38 PM
DC5DC2's Avatar
Default Re: B18 Swap cranks doesn't turn over
Check the spark plug wires if their connected the right order and check ur timing try toadvance or retard the dizzy
Old Oct 20, 2010 | 04:58 PM
OC_DC2_JDM>EURO's Avatar
i had similar problems u might wanna make sure u dont need a valve adjustment. kept my gsr in my ek hatch from starting after getting the head fixed
Old Oct 20, 2010 | 06:56 PM
JorgeD1990's Avatar
I found out what was wrong it was the cap or the end of the harnest where the feul injecters wire up to i took off the cap thingy now it runs but in high rps like 2 grand
Old Oct 21, 2010 | 12:26 PM
bigkvn77's Avatar
Bleed the cooling system. Air trapped in the fitv sometimes causes a high idle. Inspect the idle adjustment screw and make sure it is screwed all the way in. Visually inspect the intake manifold for any open vacuum ports.
trevorjohn88ef
Oct 20, 2007 06:55 PM
unrealgtx
Sep 20, 2007 08:16 PM
Vtecme92
11
Jun 17, 2006 04:13 AM
pistol
Oct 7, 2003 08:56 AM
[626]95-GSR
30
Feb 16, 2002 12:06 PM
