How do you remove the rear hatch door on a wagon?
Old Oct 18, 2010 | 03:55 PM
HT Chaplain's Avatar
Loved
Default How do you remove the rear hatch door on a wagon?
I need to remove the rear door how do you disconnect the wires?
Old Oct 18, 2010 | 04:42 PM
redbull-1's Avatar
Default Re: How do you remove the rear hatch door on a wagon?
Well, I don't know what year you have. But, generally, to remove any electrical wire, you disconnect the connector. If there is a harness wire with a rubber grommet, pull the grommet out so you can see the connector, then disconnect the electrical connector. You may also have to pull any plastic harness clips attached to the body of the car.
To remove the door, you would remove bolts, nuts, and clips you see. If there are hydraulic support struts, you may want to prop the door up first, then remove the struts. You may have to pry some plastic covers to expose some bolts, nuts, and clips.
Old Oct 18, 2010 | 04:52 PM
Loved
i removed the grommets but didnt see any connectors?
Old Oct 18, 2010 | 07:39 PM
dragon_lowrider's Avatar
The connector for the wagon is on the driverside behind the plastic and headliner, you have to remove the side pillar plastic, and pull the headliner down slightly, and there is the connector
saltsportsman
Honda CR-V & Element
Feb 28, 2018 08:47 AM
AlphaKennyWun
10
Dec 28, 2009 07:41 PM
bopbop93030
May 14, 2008 12:45 PM
Toroke
Apr 14, 2006 03:55 PM
verseone
Sep 11, 2003 07:41 AM
