GA Staggered Aggressive Work Vs-xx 4x100
well as far as I have seen these are the only set of 17" staggered 4x100 vs-xx with lips this big. so you can truly say you own a one off set of works. wheels are mint condition barrels are pretty dirty but thats about it. i can clean those up no prob. got the a few months ago and love them just wanting to see what else is out there. dont have time to build my car yet so might as well try to change the wheels
17x8 +22 fronts
17x9+ 34 rears
205/40-17 nexxan tires which are new
fit perfect with a nice fender roll i had them super flush when i was static with about half the tire tucking.
looking for $2k or trade with cash on either end if needed.
on to the pics
17x8 +22 fronts
17x9+ 34 rears
on to the pics
Rare gunmetal with polished lip 17x7.5 +35 all around Work RSZ-R in the process of being refurbished with new wheel decals and with tires falken 912s in the front and 452s in the rear. interested?
Aw man, I thought you also had 75mm/62mm. Would be nice to know there are others with more dish on VS-XXs.
Your current specs:
17x8 +22 (A disk) (62mm lip) (C inner)
17x9 +35 (A disk) (62mm lip) (E inner)
Your current specs:
You're not the only one with 75mm and 62mm lips. Why not swap the disk faces and go reversed staggered? https://honda-tech.com/forums/showth...1#post44065164
Your current specs:
17x9 +32 (O disk) (75mm lip) (D inner)
Change face will result in:
17x9 +22 (A disk) (75mm lip) (D inner)
17x8 +32 (O disk) (62mm lip) (C inner)
Your current specs:
Hey thanks, you got a great set too! Ah, I see where I saw wrong. You indeed have double A face with C and E inner barrels. No point swapping then, they will end up the same.
The max with my current roll/pull, I would go x9+22A & x8+32O but need a pair of D inner barrels. WORK had discontinued them this summer. I did manage to get a new pair of 75mm outer barrels from them in March. I have to say, your stance is amazing. Tucking on 17s...
Good luck with sale/trade my friend!
kaluwa3
Wheels
38
Jan 13, 2009 06:27 PM
kaluwa3
Jan 13, 2009 06:25 PM
No-Gi
Wheels
30
Nov 20, 2008 06:17 PM
