misfire maybe? need help..
Old Oct 18, 2010 | 02:21 PM
joeskyline06's Avatar
Default misfire maybe? need help..
i changed the tps in my car last week, drove it for 3 days and it was fine, then last night when i was going home from work, i was getting on the interstate and got into it in 3rd gear and at about 45-50 mph it started bucking really bad and spitting and ****. any clues why its doing that?
Old Oct 18, 2010 | 02:23 PM
Default Re: misfire maybe? need help..
oh yeah, its a 89 si d16a6) swapped hatch
Old Oct 18, 2010 | 02:31 PM
it was also doing that in 2nd when i got into it hard too, but if i changed gears it was fine again
Old Oct 18, 2010 | 05:38 PM
any help? anyone?
Old Oct 18, 2010 | 09:05 PM
TeamRedline89Hatch's Avatar
Any cel/codes?
Old Oct 18, 2010 | 10:31 PM
my battery light is on, the car runs great otherwise, till i take it to a certain speed in each gear, then it will start bucking like its not getting gas or something, its hard to explain really, if im in neutral i can take tach it out and it wont do it.
Old Oct 18, 2010 | 10:52 PM
chansta's Avatar
if your car never had problems before u changed ur TPS then that is most likely the issue...
Old Oct 19, 2010 | 06:49 AM
well it needed a new one because it was throwing a cell and that was the problem, so i ordered a blox one off password jdm and put it on, it ran like a top for a few days, then it just started acting up again, could it be that i didnt put it in at the right angle? because there was room for when you have the bolts in u could twist it probably a 1/4" because the bolt holes were kinda long and looked like they were made for that
Old Oct 19, 2010 | 07:22 AM
also i just went and checked i have oil in my spark plug tubes, altho i changed all those seals, plus valve cover gasket and gromets last week. any clues? im pretty sure thats what makes the car do what its doing now
djxtc65
Jan 31, 2006 09:48 AM
brad 1.cam
21
May 15, 2005 07:00 AM
Beezle
Mar 31, 2005 10:45 AM
Confuc1ous
Sep 6, 2003 05:13 AM
