Civic TypeR part out!CTR,ITR,Mugen,GT30R,Recaros,Turbo,Slicks,Topmo unt,GSR SWAP,Rims
Old Oct 18, 2010 | 11:19 AM
90Rexx's Avatar
Default Civic TypeR part out!CTR,ITR,Mugen,GT30R,Recaros,Turbo,Slicks,Topmo unt,GSR SWAP,Rims
CHECK OUT NEW LOW PRICES ON EVERYTHING!
Parting out a Complete 1997 Civic Hatchback. Lots of OEM goods, Civic type R OEM parts, 374 whp turbo setup part out, recaros, slicks, GT30R, and MORE!!
Prices do not include paypal or shipping unless otherwise stated
I Accept Paypal. Regular transactions only, no paypal gifting please.
You can also text message me for a faster response - 508 567 8748. NO CALLING.
Authenic Mugen Twinloop Catback. System is for EK9.
Comes with authentic Mugen B pipe
Price $750 obo
JDM ITR Gutted cat
Price $ 80
96 Spec JDM ITR Header
Price $ 175
OEM Civic Type R Guage Cluster. about 90,000 KM's on it. mint condition
Price : $275!!
Steering wheel from 2008 Civic FD2? looks awesome - Modified to Fit EK's
Price : $250
Kinetic Motorsports 45 degree 2.5 inch coupler $30
Vibrant 90 degree tight radius 2 inch coupler (for coming off turbo) $25
Vibrant 90 degree tight radius 2.5 inch couplers $20 each
GM 3 BAR MAP Sensor with Pigtails
Price : $50
Autometer voltage Guage $25
Autometer Oil pressure Guage - SOLD
Autometer 96-00 Civic Gray 3 guage FULL PILLAR pod $25
Integra Tail lights, driver side has about 3 inch crack in lense, not broken just crack $70
Integra bumper lights $20
STUFF NOT PICTURED YET, BUT STILL FOR SALE
NRG Traction Bars for EK $180
Rear Seats (gray) $25
Rear Quarter interior trim $35ea. side
Manual Mirrors $20 ea.
J Series wiring harness. BRAND NEW never put in a car. Was a special order from Honda. Exact application is 02-05 accord 6 spd V6 $120
96-00 Civic Seats. Fits 92-00 i believe. Everything works. has 99-00 EX material pattern
$60
Sparco Seat brackets to fit any sparco or similar seat into 01-05 civic. $30
Civic fuel pump $ 10
OBD1 GSR injectors, all working. $15 each or $40 for a set of 4
injector resistor box $25
D series alternator, bracket, and belt. Never used it so i cannot guarentee its condition $15
OBD1 P75 ECU ( integra LS) SOLD
OBD0 PR4 ECU moates chipped with turboedit for LS on 11 Psi. $35
OBD2 P2E( i think ) ECU ( 97 civic dx sohc 5 spd) $20 SOLD
b series halfshaft $50
Exhaust housing for a GT30R or other 57mm turbo with a DSM manifold flange. $75
TiAl Small red wastegate spring. Real TiAl spring. $15
B16A cams $25
integra rear sway bar w/ endlinks, bushings, and brackets. Ready to install. $35
Gsr Throttle bodies. One has FITV and TPS, other is bare with no FITV $30 each
Oil pressure sender $8
B series Fast idle valve FITV $20
Missing Link $15
B series electric VSS $35
about a foot of Stainless Braided line, The size you would use for turbo coolant lines. forgot what AN size. $15
Below it is a T fitting for an oil pressure sender on the back of the block for a turbo feed or oil pressure guage. $8
96-00 Civic hatchback Passanger Taillight and bulb tray. $20
96-00 Passanger side manual Mirror $15
Integra tan airbag, no damage, plug and wiring is good. $20
CX racing 45 degree 2.5 inch intercooler pipe with bead rolled ends $15
OBD1 Ecu Pins. $3 shipped each, or 2 for $5. Or Buy a whole connector for $15
A - B Series A/C bracket $25 SOLD
B - A/C Tensioner Pulley $10 SOLD
C - B Series Transmission Torque mount Bracket SOLD
D - GSR Intake manifold support bracket $10
E - B series bracket $6
F - B series bracket $6
G - b series bracket $6
H - civic/integra (all) power steering resevour bracket ( almost brand new) $10 SOLD
A - Evap canister for 96-00 civic $10
B - Evap canister for 88-91 civic $10
C - purge Valve and canister for Gsr SOLD
D - B series spark plug wire set $10
E - upper rad. hose for B series $10
F - Clutch slave bootie D,B series ( maybe H,F?) $5
A - Integra/Civic Power steering resevour $15 SOLD
B - Integra/Civic Power steering resevour $15
C - 99-00 Civic Si Power Steering pump ( hard to find!) SOLD
D - D series Aluminum A/C bracket $15
E - integra Driver side mount $10 SOLD
F - B series 5 spd transmission mount $25
Old Oct 18, 2010 | 04:45 PM
90Rexx's Avatar
Default Re: Civic TypeR part out!CTR,ITR,Mugen,GT30R,Recaros,Turbo,Slicks,Topmo unt,GSR SWAP,
first bumpp
Old Oct 19, 2010 | 04:01 AM
90Rexx's Avatar
Bump for the first morning
Old Oct 19, 2010 | 07:01 AM
90Rexx's Avatar
bump for lunchtime
Old Oct 20, 2010 | 03:58 AM
90Rexx's Avatar
day 2 bump
Old Oct 21, 2010 | 03:59 AM
90Rexx's Avatar
thursday morning BUmp
Old Oct 22, 2010 | 04:20 AM
90Rexx's Avatar
bump
Old Oct 22, 2010 | 01:53 PM
hondalover91crx's Avatar
how much for the complete shell?
Old Oct 22, 2010 | 05:19 PM
blkdoutteg's Avatar
Hey do you still have the half size radiator? id be interested in that, could you send a few more pics of it if so?
thanks.
Old Oct 22, 2010 | 06:46 PM
epolanco_ek4's Avatar
how much for the wing shipped and pp to jersey?
Old Oct 23, 2010 | 03:48 AM
90Rexx's Avatar
saterday morning bump
Old Oct 23, 2010 | 09:39 PM
thanks for response
Old Oct 23, 2010 | 11:35 PM
Amed Irizarry's Avatar
G/L On Sale Bro
Old Oct 25, 2010 | 04:26 AM
90Rexx's Avatar
thanks, bump for monday morning
Old Oct 25, 2010 | 08:00 AM
aeros's Avatar
condition of the motor?
Old Oct 25, 2010 | 11:17 AM
90Rexx's Avatar
condition is excellent. 180's across the board on compression. no leaking/seeping gaskets even. Motor will come with a wrinkle valve cover WITHOUT AN10 fittings too, so no need to worry about blocking those if your going N/A
Old Oct 25, 2010 | 07:37 PM
TTT
Old Oct 26, 2010 | 04:20 AM
90Rexx's Avatar
morning bump
Old Oct 26, 2010 | 11:44 AM
90Rexx's Avatar
BUMPP
Old Oct 26, 2010 | 05:04 PM
90Rexx's Avatar
evening bump
Old Oct 28, 2010 | 04:20 AM
90Rexx's Avatar
BUMP
Old Oct 29, 2010 | 04:07 AM
90Rexx's Avatar
morning bump
Old Oct 31, 2010 | 09:22 AM
90Rexx's Avatar
bump
Old Nov 1, 2010 | 02:42 AM
Bruno Miguel's Avatar
PM' Send
i still don't have news from you ....
Old Nov 1, 2010 | 11:10 AM
Why you dont answer to my PM's ?
