12v chassis leak? short? car wont start...
Old Oct 18, 2010 | 10:03 AM
884doorwhore's Avatar
Default 12v chassis leak? short? car wont start...
my car has gremlins
we traced a short to a 4 wire plug coming from the ignition to the fusebox...
replaced both ignition wiring and the fusebox... with known good pieces
we have tried tons of stuff... including main relay lol
basically 12v is leaking into the chassis... when you jump the starter when the 4 pin plug is connected, the dashlights light up... bad 12v leak...
when its disconnected, the starter will spin, but when connected, it just pops...
any ideas where the wiring is bad?
its the wires that the 4 pin grey conector going from the ignition to the fusebox that are the culprit, but we already replaced the ignition wiring and fusebox...
please help
HABITEX
Honda CR-V & Element
Jul 8, 2020 10:56 AM
iphatcrxi
Sep 16, 2004 09:20 AM
