GSR/No Oil.. new pump
97 gsr motor
Comming home from work the oil light came on.. and i haven't gotten into vtec since i can remember.
So wen i got home i turned the car off and took it the next day to the shop(via flatbed btw)
Shop then returned it with the oil light still on but installed a new pump that i had bought directly from Acura.
About 2 weeks later I heard a weard noise.. turned out it was my cams from oil starvation. Took off oil pump and then went to Acura.. got a replacement and installed it.. now i go to turn it on same thing goin on..no oil to my head and the oil light still on any ideas?
Sent block to get cleaned in solution(they said), crank cut.. block honed, new bearings, gaskets and rings.
Head got resurfaced and cleaned
all is brand spanken new.. mobile 1 filter and sythetic oil... new pump from acura.. wen i was installing it people on honda tech said it doesnt matter how it goes on.. pickup is fine and gasket is in place and properly torqued... and oil orifice was cleanned... and then i thought maybe somethin was clogged and i just removed the head from the first post till now.. and the orifice hole/pathway is clean as a whistle with no oil in it.. took off the oil filter and no oil really(just the oil i put in when i install the filter)
any ideas??
any ideas??
its pumped oil before.. all though it is alil bent... heard of people having bent oil pans no prob..
All i know is if i have my pan and exhaust bolted up.. no oil gets pumped.. i unbolt it and have the pan sustained with a jack i get oil going everywhere; even the oil light on the dash goes out.
/thread
-thanks!
insidiouseg-6
24
Jan 20, 2008 10:06 AM
