h22 swap
Old Oct 16, 2010 | 06:16 PM
jojo ethan's Avatar
Default h22 swap
so i put a h22 in a 1994 accord and got it running today run strong but check engine light stays on cant find the problem any answers
Old Oct 16, 2010 | 06:24 PM
brianb242's Avatar
Default Re: h22 swap
have you tried retrieving the code?
Old Oct 16, 2010 | 06:29 PM
jojo ethan's Avatar
no but I will do that next thank u
Old Oct 17, 2010 | 09:04 AM
Adancito's Avatar
Try retrieving the code...do the paper clip trick!
Old Oct 17, 2010 | 09:33 AM
jojo ethan's Avatar
Wat the paper cliP trick
Old Oct 17, 2010 | 01:20 PM
AccordParts's Avatar
You might have a bad sensor. Make sure you have everything connected. I would definitely check the ECU codes.
Old Oct 18, 2010 | 05:23 PM
tommygun89hb's Avatar
not being a dick here but it makes life easier on you when you check your codes FIRST that way your not pulling your hair out looking for a problem the ecu already knows the answer too
Old Oct 18, 2010 | 09:07 PM
nus_dogg's Avatar
There's a blue two pin connector under the dash on the passenger side. You'll need to stick your head under there to see that blue two pin connector and use a paper clip or some sort and jump those two wires.
Look at the CEL light and it will give you some long blinks then some short blinks. Be sure to count how many long blinks you get and how many short blinks you get. If it gave you two long blinks and two short blinks, thats code 22 for example. It will keep repeating those blinks if there's only one code saved in the ECU.
Old Oct 20, 2010 | 07:02 PM
jojo ethan's Avatar
so i finally fixed the check engine light it was the knock sensor fixed it running good hits vtec thanks everyone that help me
fastrcars
Jun 26, 2010 08:54 AM
PGT Driver
Dec 7, 2004 12:39 PM
DeDonDeRosa
Oct 2, 2004 05:22 PM
haulinazhondaboy77
Dec 6, 2003 07:10 AM
kasper
Apr 2, 2003 04:42 AM
