Integra kickin my BUTT!
Old Oct 16, 2010 | 01:41 PM
90ZCREX's Avatar
Default Integra kickin my BUTT!
01 Acura Integra, No start, cranks fine. No cel and no codes.
Checked spark, getting spark for the first couple revolutions but then cutting out and unless the key is turned off and back on, no spark.
Hearing the fuel pump come on. Removed line from filter anyways, getting good fuel to rail but not getting fuel from injectors,
Getting 12v to one side of each injector but no pulse on other from ecm.
Checked and resoldered joints on main relay, same problem.
Checked voltage at ecm while cranking, keeping around 10v.
Replaced dizzy thinking maybe a bad sensor in dizzy but still no dice.
Anyone have any other good ideas? this is driving me nuts!
Old Oct 16, 2010 | 02:17 PM
90ZCREX's Avatar
Default Re: Integra kickin my BUTT!
I hooked up another scanner and I am not reading any engine rpm when cranking the engine. Which sensor is the input for rpm to ecu?
Old Oct 16, 2010 | 02:40 PM
DA9toED6's Avatar
What about the green key on the gauge cluster? I dealt with some impossible problems on an 01 gsr and the problems ended up stemming from transponder problems from the key.
Old Oct 16, 2010 | 04:14 PM
90ZCREX's Avatar
You are the coolest guy I know thanks! My buddy got a key made at lowes
keslerbuilt
Jan 26, 2014 09:50 AM
jguzman213
Aug 30, 2012 09:59 AM
Phantastic
May 28, 2010 03:15 PM
Master23
Aug 1, 2004 08:16 PM
NewIntegraKid
Sep 3, 2002 10:09 AM
