91 Si - adding Trans Fluid?
I feel stupid even starting this thread... Looking for simple answer here, maybe some helpful pics too. I have a 91 Civic Si, looking under the hood i can not figure out where to add the trans fluid. Can someone help me out????
there is a 17mm nut located on the side of the tranny that you have to take off just under the starter...go to vatozone or kragen and get a hand pump and some 10w30 conventional motor oil (1.9 quarts) and pump it in...!!!
Look at the end of the distributor where the plug wires come out of, then look straight down. It is a plug sticking straight up out of the transmission with a lead coming out of it which hooks into where all the other sensors lead to.
EDIT: I posted the location of the REVERSE sensor, which is what many people use to fill the trans. Why you'd use the speed sensor which is more of a pain to get to than the actual transmission fill bolt is beyond me.
littledude56
Jan 9, 2010 05:05 PM
myjavelin
Mar 22, 2006 04:12 PM
