Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
sputtering and smoking - 2007 civic si sedan
Old Oct 15, 2010 | 03:18 PM
PROFILES2000's Avatar
Icon6 sputtering and smoking - 2007 civic si sedan
I am having a problem with my 2007 civic si sedan. It is sputtering at times (not all times) when I am in first gear. I can feel it in my clutch foot. Then When I was on the highway i wound out a gear and i noticed that there was a little bit of smoke. I wasn't able to see the color of the smoke. I checked the smell of the tailpipe and it smelled of fuel.
the car is 100% bone stock and has about 62000 miles on it. I have always gotten my oil changes at 3000 miles.
Any help here?
thanks in advance
Old Oct 16, 2010 | 11:20 AM
bee guz's Avatar
Default Re: sputtering and smoking - 2007 civic si sedan
Has it put on the check engine light? you should take to an auto parts store that will read the codes, most do for free.
If it is missing at times it should tell you on the read out of the codes.
Also check and see if the mass air flow sensor wire is pushed on all the way, that is the wire group on the air filter box right on top of the engine, as good as any place to start.
You should have a look at the air filter also just a few clips. Good Luck
Old Oct 17, 2010 | 08:10 AM
DanTheManFromJapan's Avatar
Honda's are known to burn random bits of oil and run rich in V-Tec. hopefully all is well.
Old Oct 17, 2010 | 12:01 PM
no cel.
dan - yah this is a little bit more than others.
I was thinking it was the rings.
Ill check the Mass air sensor in a few mins.
Old Oct 18, 2010 | 07:57 AM
2008fijibluesi's Avatar
How can you feel anything in your clutch foot while your moving in gear? Take your foot off of the clutch. Problem solved.
Old Oct 21, 2010 | 09:03 PM
when standing still at a light
rackshaw
Jan 7, 2017 07:19 AM
OxDseries
Jun 10, 2016 01:25 PM
jaeGizibe
Honda Civic (2001 - 2005)
Aug 4, 2014 07:02 PM
tiptopEBPcivc
Jul 16, 2009 07:19 PM
Xaero1369
May 20, 2007 12:31 PM
