hatch and sedan front bumpers, the same?
Old Oct 14, 2010 | 11:59 PM
gsr_b20b's Avatar
Default hatch and sedan front bumpers, the same?
hey guys i just picked up a 90 civic si hatch with what looks to be a ef sedan front bumper on it (random bolts drilled through the side to hold it on and its missing the top metal trim piece that goes under the headlights) i was wondering if hatches had the little metal trim piece that sits on the top section of the bumper and tucks between the headlights and the bumper too. If thats the case then could i just grab the metal trim piece off my old sedan parts car i have? but is there a difference between the sedan and hatch front bumper? any help is needed cuz it looks grose.
Also are sedan and hatch dashes interchangable? cuz the hatch i just got has a huge crack on the dash but the dash in my old sedan is mint. if it makes any difference my ef hatch is a 90 and my sedan parts car is a 89 and i could clearly tell the cluster bezel pieces are different sizes
Old Oct 15, 2010 | 04:34 AM
~sp33~'s Avatar
EFB055
Default Re: hatch and sedan front bumpers, the same?
The 90-91 sedan and hatch bumper are different, but not by much (one is slightly longer than the other). They should both 'fit' though.
They both have that metal piece (filler piece as it's usually called) but they're different and not interchangeable.
You could swap the dashes out, but the 90 model had a different cluster, which wont fit in the 88-89 dash, so unless you want to swap that as well...
Old Oct 15, 2010 | 08:25 AM
gsr_b20b's Avatar
okay thanks
HWKR3W
Jan 9, 2011 02:42 PM
InTheLBC20
Jan 19, 2010 08:27 AM
mrs2k4u
Mar 20, 2009 08:32 PM
Shonda
Feb 28, 2007 11:05 AM
dohcnotec
Sep 7, 2004 12:44 PM
