How do I get the F'n hub off?
Old Sep 19, 2002 | 09:42 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default How do I get the F'n hub off?
Ok I got the freaking 32mm nut off. Now what do I do? Thanks.
<Pissed because his R is in the middle of an apartment complex at 1am in the morning on jacks with a bunch of drunks walking around.
Old Sep 19, 2002 | 09:46 PM
D's Avatar
D
Default Re: How do I get the F'n hub off? (ActiveAero Ninja Edition)
hub?
hub is removed from the knuckle with a press... after the driveshaft has been removed, and the upper, lower, and steering ball joint separated.
D
Old Sep 19, 2002 | 09:50 PM
ZygSpeed's Avatar
Default Re: How do I get the F'n hub off? (D)
Are the bearings in there somewhere?
Old Sep 19, 2002 | 09:51 PM
bullz's Avatar
Yup. It's sucks without a car to take it to get pressed.
Old Sep 19, 2002 | 10:32 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Problem almost fixed for now. I went psycho on the new studs a banged them in with a hammer so removing the hub won't be an issue. This should suffice until I can get them properly pressed in.
Old Sep 19, 2002 | 10:44 PM
BrandonClaps's Avatar
New User
the rear you do not need to remove the hub, the front you do. for the rear all you gotta do is knock out the studs, then put the newones in, put a few oversized washers around the stud and then use an impact gun and the lug nut and tighten it down until it seats itself, not sure if it can be done with a wrench, but could give it a try
marvin75
Apr 24, 2011 05:48 AM
JaguarS4R
Honda Civic (2001 - 2005)
Oct 21, 2010 04:32 AM
airikkCRX
Jan 16, 2010 04:31 PM
JJ's civic
21
Aug 30, 2006 02:18 PM
typeeg
Jul 20, 2004 05:21 PM
