EG Brake & Suspension Parts for Sale!
Old Oct 14, 2010 | 08:25 PM
RustyE.G.'s Avatar
Default EG Brake & Suspension Parts for Sale!
I did some upgrades and need some stuff gone.
-DX brake booster/master cylinder
-DX front knuckles, driver and passenger sides. Rotors might need replaced, ball joints and wheel bearings still good. One side needs 4 studs, they all twisted off haha. Driver side caliper was recently replaced and the other isn't as new but works fine.
-DX rear trailing arms, driver and passenger. Both probably need new shoes, I believe the drum covers are fine. Driver side needs a new wheel cylinder because the bleeder valve snapped off inside, but those are like 12 bucks at autozone.
-Stock struts all 4. The rear driver side had a bolt stuck holding it to the LCA so I had to cut a notch in the bottom of the "fork" part to slide it off, shouldn't affect it. Also the captive nuts have been ground off both the rears for the same reason. Unknown mileage, but they still functioned just fine when they came off.
-Maxspeed lowering springs. Drop was around 1-2 inches. Had about one finger wheel gap in the front and about two or three fingers in the back.
--Other Random Stuff--
-P06 Manul OBD1 ECU
-B-series thermostat housing w/out hole for fan switch?
-B18A or B crank pulley
-B18A head studs... used, but from a motor that wasn't abused and had no probs.
-DA rear LCA's. Might need new bushings. Each side has a bushing with the remains of a bolt stuck in it. Might be able to press those out.
-DA rear sway bar. I believe it's 14.7mm, a bit thicker than the standard DC ones.
-Aluminum JDM B-series A/C braket w/tensioner
-EJ1 green spoiler w/perfectly working tail light LED's, in good condition.
-Generic glass pop-up sunroof
-D-series throttle cable
-Short throw shifter, blue aluminum, unknown brand.
*Everything is OBO*
*Prefer local pickup, but willing to ship smaller/lighter items*
*Pictures available upon request*
Old Oct 14, 2010 | 08:40 PM
boostedbatch's Avatar
Default Re: EG Brake & Suspension Parts for Sale!
location and price of shifter
pm me
Old Oct 14, 2010 | 09:00 PM
variable's Avatar
price on drop springs?
Old Oct 15, 2010 | 01:32 PM
RustyE.G.'s Avatar
PM's replied!
Old Oct 16, 2010 | 09:54 AM
RustyE.G.'s Avatar
Bump! Willing to negotiate on anything, just need this stuff gone and need rent money.
Old Oct 17, 2010 | 12:01 PM
RustyE.G.'s Avatar
Bump!
Old Oct 19, 2010 | 09:03 PM
RustyE.G.'s Avatar
Bump
Old Oct 24, 2010 | 03:13 PM
RustyE.G.'s Avatar
Bump! Buy my junk!
Old Nov 15, 2010 | 04:09 PM
RustyE.G.'s Avatar
Passenger side trailing arm sold. I'm letting this stuff go for cheap, just want it gone.
bacardiboi
Sep 13, 2009 08:21 PM
bacardiboi
Suspension & Brakes
Sep 13, 2009 08:12 PM
{CHOPZ}
14
Dec 20, 2008 04:04 AM
bads2k
Jun 28, 2007 08:11 PM
car-toons
Mar 11, 2004 06:20 AM
