Help: EG sir headlight install
Old Oct 14, 2010 | 06:22 PM
bmbarnum's Avatar
Default Help: EG sir headlight install
Hello everyone,
I am trying to install some sir headlights into my EG, but the only problem is that I know nothing about cars, let alone wires. When I pop open up the hood, it looks like removing the headlights already installed are easy which is just removing the bolts. Now, what to do about the wires? I know I have to do some wiring with the sir headlights and this is when I am completely lost. Do I just cut the wires and attach the wires together with those wire clips I can purchase at Autozone? I am providing some pictures cause I have absolutely no idea what to do. I know I could always pay someone to install it, but I would really like install them myself to be able to say, "I did that." Also, I am trying to install the city lights and all. I need a relay, I believe. I am sorry I am such a noob at this thing. I wish I got into cars a lot younger and took some auto classes
Anything will honestly help me! I did search for some DIYs but did not find anything helpful for someone of my level.
I am so bad at this. Which wires go to what?! haha. Any help much appreciated, even if it's a negative comment on how sad I can't even install something so simple. Thanks in advance guys!
Old Oct 14, 2010 | 06:39 PM
KevinBrown's Avatar
Default Re: Help: EG sir headlight install
The only thing you should have to wire yourself is the city lights, and I'm honestly not completely sure how to go about doing that. If you do it, make sure you take your time and do it right.
The headlights/corner lights should be 100% plug and play.
Old Oct 14, 2010 | 06:44 PM
kaiba's Avatar
City light can be wired to the parking light. The wires can be found on the corner lens. There should be 3 wires. Connect to only two.
Old Oct 14, 2010 | 06:57 PM
bmbarnum's Avatar
Thanks for such a quick response guys!
So, if I were to connect the wires of the city lights to the corner lights, I would just cut and connect the wires with one of these, correct?
Or do I use something else?
Old Oct 14, 2010 | 07:20 PM
KevinBrown's Avatar
Personally, I'd stay away from those. Splice into the wires, using solder and heatshrink.
Old Oct 14, 2010 | 08:10 PM
kaiba's Avatar
Black tape works too.
Old Oct 14, 2010 | 10:03 PM
methos713's Avatar
solder and heatshrink is better and has a cleaner look.
TASAuto.com
Apr 14, 2008 12:25 PM
wootiewoot
Feb 23, 2008 04:42 PM
chigsu
Oct 1, 2003 08:44 PM
95accord22
Aug 20, 2003 02:05 PM
