WTB : RC310
If interested, I have a set of Bosch plug and play 330cc injectors with a 1 year warranty. These Bosch injectors are much better than the Lucas injector (that RC uses) because they have a much better atomized spray pattern. This set has been fully serviced and will come with a test report. Asking $160 shipped to Canada.
Here is something to think about when upgrading to a higher flowing injector. Most performance brand injectors rate their injectors at an industry standard static flow rate of 43.5psi of fuel pressure. If you take a stock 240cc Honda/Acura injector it will flow about 280cc at this same 43.5psi fuel pressure. Honda obviously used a different fuel pressure to rate their injectors. I just hate to see money wasted on injectors that flow close to stock or even flow less because few know how injectors are rated. So technically speaking your are only upgrading to a 10% higher flow injector with an inferior non-oem spray pattern. Hope this info helps out some people.
